EWS Problems Heeeeelp Please!!!
Hi All
I hope somebody can help.
I was cleaning up errors with on my car with PA soft, because I had replaced a abs sensor.
I also found an error on the ews, so I went into the ews option, coding and then into settings and manufacturer data, and now beguines the stupidity
, and don't ask me why but on the DME/DDE Interface I changed ews 2 to ews 3, thinking if anything whet wrong I could change it back, I found out that you can’t change it back.
Well now the car won’t start and I can’t change it back to ews 2 because the option is in light grey and want let me press on it.
So I went in to the ews with NCSEXPER, I found that the ews had "EWS_3_SCHNITTSTELLE" is set to "aktiv", but should be set to "nicht_aktiv"
I tried changing it but I get the following error
Could anyone help me out???
, and don't ask me why but on the DME/DDE Interface I changed ews 2 to ews 3, thinking if anything whet wrong I could change it back, I found out that you can’t change it back.Well now the car won’t start and I can’t change it back to ews 2 because the option is in light grey and want let me press on it.
norsecarnut
Jun 27, 2015 05:47 PM
