xenons flashing after starting engine for 5-10 seconds
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
i have fitted a xenon kit on my e60 the lights start to do a strobe affect after the engine is started is there a way to disable this by ncs?
i have the error decoders fitted so no error for bulb out
once let to settle for 5-10 seconds they stay on fine and when engine is off they light up fine every time
hi blood its like a sos light they flash go off flash go off and eventually they will come on stable
only happens when the engine is started then they are turned on
if i turn them on postion 2 they power up and then i start the car they are fine
they flicker on and off for 5 seconds or so
Engine: N54
no flicker at all on my OEM xenon
I researched around on the net it says the lma module causes this as the ballasts try and draw too much power at startup and the when the car is started it is checking the connections ad headlight system
thesalboy
04-08-2015 09:13 AM
