V1 Hardwiring
Old Jun 26, 2004 | 05:09 PM
  #21
JDN's Avatar
JDN
In retrospect, wiring into the o'head panel was simple enough. I think the first apprehension was because the connector had not gone through the insulation of the wire, but evidently bit through slowly. Grounding into an existing screw (motor mount?) was also simple enough. I am happy with this DIY installation and appreciative of those on this board who guided me.
Old Jun 26, 2004 | 05:14 PM
  #22
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
I wrap cable around the steering wheel twice (too long). Finally, velcroed the concealed module. Voila! No visual from the main V1 (Dark Mode). Mute and Mode selection are controlled by the Control Knob on the Display (On-Off and Volume adjustments remain on V1).
Of course this concealed unit is another option, V1 works great without it.
Old Jun 26, 2004 | 05:40 PM
  #23
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Looks good Rizbel. Only problem is now you can't see that wonderful MPG gauge that BMW seems to think we all must have!!
Old Jun 26, 2004 | 05:47 PM
  #24
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Never did care for that mpg gauge, Rudy. Should have been the temp. gauge instead.
But it still is visible from driver's view.
Old Jun 26, 2004 | 05:52 PM
  #25
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Rizbel' date='Jun 26 2004, 09:47 PM
Never did care for that mpg gauge, Rudy.? Should have been the temp. gauge instead.?
My E30 M3 has an oil temp gauge there but all my E39's had that useless vacuum powered MPG gauge.
[rant] What is this, 1975 all over again? Do we really need to see the instantaneous MPG readings? [/rant]
Old Nov 17, 2005 | 06:23 AM
  #26
katheikia's Avatar
My Ride: 2006 550 SMG
I tried to hardwire my V1 last night for one hour with no success, I atached the power to the green wire a couple of inches above were it conects to the sunroof switch, does it matter what part of the green wire you attach to? and grounded it to one of the torque screws, could not get it to turn on. Im very upset, after all that, nothing happened. Any sugestions?
Old Nov 17, 2005 | 06:38 AM
  #27
JDN's Avatar
JDN
IIRC, the green wire you mentioned should have some yellow on it, too.
If that part is OK -- as far as not having power the first try, I had that problem too. I solved it by clamping down harder with the stubby plug to get the contacts through the insulation.
And, make sure you have the ground wire securely anchored under a screw above the headliner.
Old Nov 17, 2005 | 06:45 AM
  #28
katheikia's Avatar
Does it matter wich screw I ground to, I used the torque screw that hold the little siemens box? I have clamped into the green wire hard enough, that when I took it out, I can see the bare wire showing
Old Nov 17, 2005 | 06:59 AM
  #29
JDN's Avatar
JDN
Any screw into metal should work.
Alfano
Jul 29, 2015 05:23 AM
ssibaroma
Apr 29, 2009 01:13 PM
AKAlius
Nov 14, 2008 09:21 PM
dv8ed
Bluetooth & Cell Phone Forum
Aug 8, 2006 08:11 PM
bleudyno
DIY: Do It Yourself
Mar 6, 2006 07:16 PM
