upgrade navigation systen
Old 09-21-2010, 08:20 AM
arsinte_andrei's Avatar
and by the way.....do I have to disconect the battery when I 'm doing all this?
Old 09-22-2010, 02:06 PM
Originally Posted by BLooD
OK no need to change the controller, this applies to pre-LCI cars. yours is an LCI.
CCC fan and cable 65836933200 £46.88
Centre console top trim for CCC 51456976362 £23.97
Bottom centre console trim I will need to know what wood finish that is as there is loads of trim finishes.
can you have a look in photos to see what wood is that?? and what is it part no and what else do I have to change?
do I need the microphone ? and ... another few thing that bmw told me that I will need? (like wiring set, wiring harn, cover, microphone .... from retrofit kit???)
Old 09-29-2010, 04:00 AM
now it is done... without need of programing.
everything work perfect.. except usb is not working, it not accept full post code for uk....
Old 09-30-2010, 12:19 PM
any way.. good news.. I already have usb into my car.. and the usb module is with bluetooth... all I need is to fit a harness with microphone and a bluetooth antena.. and then coding...
but can some one help me about coding? do you know what tools can I use to code my car? is ok is I will buy an ops? my car is february 2008 or OPPS I know that this is not possible via the obd2 should be deffinitly optical cable programing/coding
Thanks
Old 10-03-2010, 05:10 AM
nick530's Avatar
My Ride: 2006 530d M Sport Titan Silver with Black Leather Interior, Style 172 19s, Sunroof, Professional Nav CCC Retrofit (thanks Patryk), Bluetooth.
So I missed something...did you end up needing the extra parts?
I am in the process of doing this also. I have the CCC unit and screen, not sure if I need anything else???
Old 10-03-2010, 07:20 AM
you will need also an LDVS cable (between display and CCC unit)
also I need the trim that is comming under the plastic trim for the ccc and the heatting console...
If you have an part no and do you have what I need.. please let me know... I'm from London...
my car is wood finish..as you can see in top photos
Old 10-03-2010, 07:25 AM
Like that is now my car...
As you can see this wood finish trim I need...
like that is now...
and this is now the monitor...
Old 10-14-2010, 12:05 PM
GhostWorks's Avatar
Attachment 112238
like that is now...
Attachment 112239
Attachment 112240
Thats good
Makes me feel beeter to know it can be done
Old 10-18-2010, 10:17 PM
ulvit's Avatar
Could you post a DIY. This is a fantastic mod that i am sure many PRE-LCI would like Including ME!!!!!
Parts list and what to do....?
PLEASE....>!!!!!!!!!!!!!!!!!!
Old 10-19-2010, 12:09 PM
GhostWorks's Avatar
Same here
Bump
Quick Reply: upgrade navigation systen
