Service
My Ride: May 2008 530D "M" package Exclusive line.
Hello,
Can anybody tell me how to access the service menu on a E60 ?
I was used to it on the E46 but this one...
Thanks
Thanks
on the idrive on the main screen, push the knob down once. then scroll down and youll see "service" towards the bottom. scroll until that is highlighted then push down on the knob again. i think that is what youre talking about. also, im not 100% sure if it is the same for the LCI models though. hope this helps.
Hi,
Well, I was talking about the "hidden" menu (not visible by the customer)...
But thanks anyway.
Etienne
But thanks anyway.
Etienne
Originally Posted by Etienne' post='454131' date='Aug 1 2007, 11:04 PM
Hi,
But thanks anyway.
Etienne
But thanks anyway.
Etienne
The secret men? ?
Keep pushed the button on the instrument cluster .. Then push many times till men? 19, insert the code to unlock .. and then you will have 8 undermen?, with all datas: battery voltage, litres of gas you have in the tank, temperatures, rpm, consumption etc..
You will obtain the unlock code adding summing numbers you will find in the first men?: mine, for example, is 31 . Check for your one!
Originally Posted by Etienne' post='455191' date='Aug 4 2007, 03:03 PM
Thanks for the trick Alex,
'll try this...
I'll keep you informed.
'll try this...
Don't esitate to send me a PM, if I will not answer here .
Tomorrow, for example, I would like to verify the rpm limiter (men? 04, if I remember correctly) .
Welcome and enjoy the forum!
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
