Self Installation of Dension Gateway 500
#52
My Ride: BMW E61 530xd 2007 LCI Touring
Could you please help me!
I connected Dension using some alternative optic line I found on the left to the glovebox.
CDC stayed connected with fabric optic line.
It turned out that on my car serial connection of "Car line - Dension - CDC is not working". iDrive can not read nor CDC (switcher on dension aux on cdc-mode) neither Dension (switcher for regular way).
Switching to the CDC mode doesn't give right effect. Dension won't work but CDC won't work as well.
I really don't need CDC myself but my wife is using it and don't want to know anything about ipod...
My car is 2007 lci with naive prof.
#53
Ok,,
I am a bit confused by all this.. I am wanting to fit the Denison 500 in my 2005 e61 with professional sat nav...
I don't think my car is mp3 coded... I have just taken an mp3 disc (just created) out to the car and put it in the slot and the changer. Each time, the selection on the screen was greyed out so I couldn't play mp3's in the slot or the changer...
Now - I belive I can still install and use the Denison 500 but I wont be able to see the track names on the screen? If that is true I will need to get the car coded. I plan to install my ipod in the glove box and leave it there.
Can anyone 100% confirm if I am correct that I need the car coded and if thats the case what do you think BMW would charge to do this?
Thanks
Paul
Thanks
Paul
#54
Question for the OP. In your photo below, you see the black connector that joins the fibre from the dension with the fibre from the car. Was that connector supplied with the dension? I have no CDC so will it be wired differently? The 2 fibre + 2 power cables are in the one connector inside my glovebox, since the car has CDC prep
#55
Thanks for the excellent write up...This guide is if you have a CD changer but if you dont have one then would you still find the same cables behind the dasboard?
Many thanks
Many thanks
#56
![](https://img193.imageshack.us/img193/5884/post159901198682380.jpg)
Her is my question:
Do these 2 green fiber optic cables qualify as Installation type 3a according to Dension Installation manual?:
![](https://img812.imageshack.us/img812/6348/51549652.jpg)
I have two fiber optic cables directly connected to Dension 500 according to this type of installation. Is this correct?
I have BMW 5 (E61) 2005 model with Professional NAV and Radio, single CD and CDC preparation. After installing the Dension according to above pictures and explanations, I tried to activate the Audio system using Activation Dongle from Dension specially made for BMW. All I got was CD1 to CD6 ( instead of iPod) and still not able to listen my iPod.
I also had BMW actory installed Bluetooth system in the car, after this activation process I also lost the Bluetooth connection and unable to find it.
Any help appreciated
Engin
#57
My Ride: 2008 535i JB4
Hello,
I have a 2008 535i with Nav, mp3 but without CDC. I have the pre-wire and will need to get coded for CDC.
I am working on installing GW500 and got the optical cables separated from the connector and connected to the adapter.
I'm not sure what to do with the power. I got a used unit with a "5" fuse (I'm not sure what it means) already on the line. Do I keep this on the line or use without?
Also, do I need to disconnect the battery to "tap" into the power? I was going to remove the original BMW connector and tape on the "new" one with the fuse on the line. Should I go to Radio Shack or something to get a real tap for a more secure power connection?
Is this correct?
thanks
-p
Is this correct?
thanks
-p
#58
What was the solution to make your system work?
I have a 07 530i with prof Sat Nav & CDC preped,no CDC installed, I could not find the fiber optic cables but found the power connector. Did you have to buy & install another fiber optic cable? What do you mean by fitted it differently?
#59
has cd changer in my e60 which cannot play mp3 and dvd slot with mp3 playback
tried to install dension 500 but nothing is working.
got the blue light on the aux thingy but that's it...
any help will be great
#60
My Ride: 05 545i retired. 11 550i w/sports package
Check out the website.
GW51MBE - Dension Gw51mbe Ipod Gateway Enabler Tool With Gateway 500 For Bmw Vehicles With Most System (Ipod Adapter With Enabler Tool) - Dension
