Sat Nav Pro retrofit/ how do you handle it with existing bluetooth pho
#21
hey i was reading this post and was very interested. I am in the process of buying the parts for the retrofit and have a few questions:
1. do i need the ccc fan for it to work?
2. can i use the same plug from my mask unit to my ccc unit?
3. does the high idrive controller need a separate cable from my original idrive controller?
any help would be greatly appreciated.
#22
My Ride: BMW E60 530i, Production Date May 2005
Hi,
1. I wouldn't consider doing the upgrade unless you used the CCC Fan, the unit does get quite hot even with fan
2. I purchased a HIGH cable to go from Pro Nav CCC to widescreen display
3. The High i-Drive console has a microphone cable from memory
Problem I had was getting my retrofit from Business Nav to Professional Navigation programmed, it errored each time it was tried, my parts came from Poland and my E60 is from Australia.
I have a couple issues but generally, it was a successful retrofit.
Cheerz
Cheerz
any help would be greatly appreciated.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
#23
Thanx for the response i have gathered the parts i need but i heard that you can use the existing video cable just switching it around. Before i start do i need to updats the software of the car?
#24
Hi,
Progman software update your car first, since the upgrade to Pro Nav I can't perform the Pro Nav Retrofit software update or Progman software update for my E60 car unless I re-install the Bus Nav parts, it throws up an error message when they try and do.
#26
Hi,
I had my E60 coded before Pro Nav update just incase, but found after I installed Pro Nav parts, when they tried to do the Pro Nav Retrofit software update, the process gets an error message and they can't proceed.
My car can't be software updated while my Pro Nav parts are installed, I have to put back Bus Nav parts.
#28
Are the Pro Nav parts brand new or from a used vehicle.
If 2nd hand Pro Nav, if you don't get the AUX installed now and Progman software updated, no guarantee they can update software if AUX installed at same time with used Pro Nav parts.
If Pro Nav parts are used, a genuine BMW dealer may refuse to install, mine in Adelaide did.
