resetting oil change in idrive
Old 06-01-2008, 09:45 AM
  #71
biotoxic's Avatar
Hi,
Tried this pushing button thing and nothing!! I can see all those logos came up but as soon as i push again to reset it, it goes back to main screen (or exclamation mark) and all oil, filter etc cames again...
Old 06-05-2008, 09:56 AM
  #72
ultrawheel's Avatar
Hi, anyone there know what is the code.. when you switch to on. there is 3 stage before starting the car. first stage turn the key slightly on and the light appear. if u press on the reset button for 10 sec than it come out some code like cm72xxxx type of thing tah press again it appear some code word. what is this ar.. any expert advise
Old 06-05-2008, 09:59 AM
  #73
ultrawheel's Avatar
Old 07-02-2008, 06:41 PM
  #74
thedreamshop's Avatar
My Ride: 2004 545i titanium grey 6 speed manual with light grey interior. Nav, L7, cold weather, sport, sat. Modifications: suede headliner, pianno black interior trim, Ipod dock, Mtech front bumper, Angel Eyes, and flat black kidney grills.
Smile
Originally Posted by liv530D' post='434592' date='Jun 11 2007, 09:59 AM
Please, anyone can help me? I am trying to reset the "braking pads warning" and when I long press the "reset" option it gave me - 15000 km...so I still get the warning ....
What can I do?
Tx
Sorry to dig up an old topic but I have the same problem. I just replaced my rear pads ( on my 04 545i ) and then tried to reset the service interval. I ended up getting -15000km which makes it look like I went over the pad change interval by 15000 km. Is there a way to reset the pad change to some factory interval like 30k mls?
Old 07-02-2008, 10:59 PM
  #75
KnIgHtCoM's Avatar
Anyone know how to reset the oil service on the push button ignition? Is it the same as the turn key? I had the dealer change my oil at the 1yr mark (10k miles). My 16k oil service light is on.
Old 07-03-2008, 09:15 AM
  #76
KnIgHtCoM's Avatar
bump.
Old 07-14-2008, 12:35 PM
  #77
alan545's Avatar
My Ride: Carbon black 545i sport
Same here! I changed both front and rear pads on my 05 545 today. The rears were at -600 miles and the fronts were at 4900 miles before replacement.
having replaced them and trying to reset the numbers using the method as described, the rears now show -15000 miles and the fronts show -9000 miles!
I think I followed the instructions pretty carefully and here's what happens :-
1. Ignition switch on and reset trip counter to zero
2. Turn key off and on again and hold in trip reset button for 5-10 secs
3. Service triangle appears and I can move to the rear pad service icon
4. Hold in the trip button and the word "reset?" appears
5. release and reapply trip button and the -15000 goes to 4 dashes ---- then goes back to -15000
If I do the same for the front pads I get exactly the same result except the number goes back to -9000
Anybody got any ideas?
Thanks
Old 07-14-2008, 07:03 PM
  #78
stankustov's Avatar
My Ride: 2004 BMW 530iA, sport package, premium package
Post
Originally Posted by nicke60gre' post='190405' date='Oct 29 2005, 02:48 AM
Hi kreate2
Welcome aboard
Press the tacho reset button in the instument cluster about 10 seconds with the key to on position, until "service" appears, then change selection with a sigle push
until "engine oil" appears. Keep pushing the "reset " ask yes? and that's all. Next oil change after 25000 Km appears on the idrive "service"menu.
Beware, not to reset another function, there is no way to restore a reseted item.
Regards.
it worked. thanks
Old 07-18-2008, 01:46 PM
  #79
ey2001's Avatar
My Ride: 525i
i had a quick question... i couldnt find it anywhere.. i have an 06 525i and i am about to do an oil change... no more warranty. what motor oil, the grade and how many do you use on the car. couldnt find it anywhere.. thanks for all your help
Old 08-02-2008, 09:22 AM
  #80
stankustov's Avatar
i buy my oil in walmart Castrol Syntec (full syntetyc oil) it needs about 6+ quarts ('04 530i)
Quick Reply: resetting oil change in idrive
