reset airbag light
i accidentlly disconnected my drivers airbag while swapping steering wheels. forgot to disconnect battery. can i reset it without dealer? doe that tool they sell for like 140.00 work in resetting the error? dont mind buying it if i can use it. just hate going to dealer
thanks
thanks
They have a bunch of tools that you can buy. I had the Peake code reader. It didn't work for me so I sold it. Not sure if I was using it wrong though. They also have another one that runs through your computer and it works for just about all BMW's. It is called Bavarian Technics. It is more expensive but IMO worth the money. Check it out at http://www.bavariantechnic.com/
My Ride: 530i
Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
thanks
thanks
thanks
thanks
fyi found a place in bronx new york that reset for 40.00. he did it it took 2 minutes. this place also codes cars without any issue. spoke to him about coding an aux input he told me installation and coding 120.00. the dealer wanted 300.00 for this alone. he deals only with bmw. the place is called haus of bimmer. also i needed to replace active steering module. dealer wanted 1400.00. he found me a used module and total with install and coding is 450.00 950.00 cheaper than stealer.
linxuan
E39 Discussion
03-22-2015 06:16 AM
