Replacing brake master cylinder and/or brake booster
Old Dec 5, 2009 | 11:40 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
For those of you daring enough to attempt to replace your master cylinder or brake booster, a new document is now available in the technical gallery that might help you out...
https://5series.net/forums/index.php?autoco...i&img=17568
Old Dec 6, 2009 | 06:19 AM
andi07xi's Avatar
Hi, I am changing front brake pads on my 530xi with EBC semi metallic pads.
I plan to drain the brake fluid in the pistons to avoid it going back in the lines.
Want to know what kind of brake fluid I should use to top it off with (DOT4 etc). Manual does not mention it.
Also want to know if it's an overkill?
TIA,
prem
Old Dec 6, 2009 | 10:03 AM
05545i's Avatar
My Ride: 2005 545i Sport 6MT
TIA,
prem
DOT 4 fluid. If you have never added brake fluid, or have no leak, you should not have to top off the reseviour.
Old Dec 6, 2009 | 01:25 PM
andi07xi's Avatar
Post
Thanks 05545i, I did not need to add any, 'coz I decided against bleeding the fluid in the calipers.
Job done...
Moving on to coolant change next weekend.
Old Dec 7, 2009 | 01:13 AM
tooltec's Avatar
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
I've looked at the brake fluid flushing and bleeding section and it seems as though it could be a bit more involved than the DIY procedures carried out by some members.
Does anyone know what "Run through bleeding routine with BMW Diagnosis & Information System" entails?
socale39
Sep 5, 2023 08:30 AM
TexaZ3
May 6, 2015 09:54 AM
MARCUS545
Aug 31, 2004 05:04 PM
browellm
Apr 9, 2004 08:48 AM
