Replacement Headlight AND Remove Headlamps DIY
Old 08-17-2010, 09:47 AM
  #51
Rasmus's Avatar
As long as the headlight is off there is no risk of shock, do not remove the battery cable.
The reason why the headlight cable is not removed is because of 2 things.
1. if you forget then you will have to remove the assembly all over again to plug it in.
2. There is a trick to removing them. On the big connector you must slide the sleeve to one side until it releases. On the small connector you have to squeeze the tang to remove it.
Make sure to test the headlight before you reinstall the assembly back in the car.
Regarding your 2): Big and small connector? I only see one connector in the guide.
Attached Thumbnails Replacement Headlight AND Remove Headlamps DIY-posted-image.jpeg
Old 08-17-2010, 09:59 AM
  #52
Rasmus's Avatar
Originally Posted by brabusw209amg
even if ur headlights are on, if ur careful, ur fine. But I dont recommend it since there are moving components inside the headlight and if u move it too much, things are start breaking.
Havent looked inside yet, but its scheduled for saturday . Even dont know yet if I need D1s or D2s, but i guess ill find out during disassembly.
Thanks...
Old 09-02-2010, 11:52 AM
  #53
chalankanoa's Avatar
My Ride: 2006 BMW 550i CPO bought in Jan 2009
Is there any worry about the headlight not being properly aligned if you remove it?
Old 09-20-2011, 11:46 PM
  #54
e60hnl's Avatar
Originally Posted by John@Motorcepts
my god. I must be tired. I totally read it wrong. I gotta sleep. Thanks! haha.
BEDTIME!!!
great post, wish i had found this post first.
had a difficult time removing the headlight unit.
See now that if i had removed the top five screws for the bumper, i would have had an easier time removing the headlights.
Great pics easy to follow.
Old 03-13-2012, 10:59 PM
  #55
daweilee's Avatar
My Ride: 2004 525i
Model Year: 525i 2004
Engine: M54
very good write-up, i will benefit from it. thank you.
Old 01-28-2013, 01:58 AM
  #56
530dE60's Avatar
Any suggestions on how to view this thread properly as the images on the first page are so massive that I can't actually read the text all the way across and also can't see the images fully as they are just too large...must be my crap monitor .
Old 01-28-2013, 11:17 PM
  #57
RTR
RTR's Avatar
Most browsers can zoom out: Ctrl key and "-" key. The text will be very small, but at least you can see the pics. Zoom back in: ctrl and "+"
Old 02-04-2013, 02:37 AM
  #58
530dE60's Avatar
Thanks for that tip...it works .
Old 02-22-2013, 01:26 AM
  #59
RoberMC's Avatar
My Ride: BMW 535d E60 *///M Pack* CarbonSwartz
You don't need to remove the rubber trim or unscrew the front bumper to remove the headlights. I have removed mine 1000's times while doing different mods.
Kasmo
05-07-2019 03:30 AM
rackhacker9275
26
04-16-2015 08:13 AM
dakest
03-25-2015 07:02 AM
browellm
04-09-2004 08:48 AM
08-12-2003 11:41 AM
Quick Reply: Replacement Headlight AND Remove Headlamps DIY
