Replacement Headlight AND Remove Headlamps DIY
#41
My Ride: '04 545i, sport pkg, premium sound, sprint booster,
Originally Posted by C's Bimmer' post='987992' date='Aug 25 2009, 09:06 AM
This is a really easy DIY, actually. I've done this for countless members and it just gets easier each time. Once you get the hang of it, it's a snap.
The only addition to this fine DIY would be to add a list of tools and items needed to complete the project.
#42
Banned
My Ride: A Car
Originally Posted by jrfinest' post='987566' date='Aug 24 2009, 08:45 PM
I just purchased a HID kit for my 06 525xi, with stock halogens . Any advice how where to mount the ballast? Also would the process be same as in this DIY? removal of the headlight is the only/easiest way? Would the install be different in my case with halogens as my stock bulb?
Use double side tape and mount it or use the bracket and find a hole and mount it. Where did u buy the HID kit? I hope they are CANBUS ready since it may flicker anbd cause error messages.
ALL HID kits out there ESPECIALLY EBAY ones DO NOT WORK! PLease dont waste money! The only kits that work properly are my kits and Roger's (schrulrog's) kits.
#43
My Ride: 2006 530xi (Titanium Grey/ Black interior) Debaged, L.e.d. light upgrade throughout. ACS roof spoiler. H&R sport sprigs, Angel eye upgrade, euro sticker, ,matte black grills.
Are those your working sneakers john. You always have those orange kicks when your hard at work. LOL
#44
Banned
My Ride: A Car
#46
Banned
My Ride: A Car
I have removed the DIYs from my signature since it's making my sig too long
this is my entire list of DIYs:
HID Information: Click Me!!!
DIY Interior LEDs, HID Foglights, Plate LEDs: Click Me!!!
DIY License Plate Lamps: Click Me!!!
DIY Headlamp Removal & Headlight Install: Click Me!!!
DIY H8 Angel Eye For LCI Xenon Headlamps: Click Me!!!
DIY HID Low Beam Conversion For Halogen Headlamps: Click Me!!!
DIY Reverse Lights: Click Me!!!
DIY Low Beam HID Conversion: Click Me!!!
#47
My Ride: 2006 E60 M5 (Sepang Bronze/Natural Brown)
Eisenmann Exhaust with Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi Scoops & Block Off Plates with BMC Filters
Eibach Pro-Kit Springs
20" Breyton Race CS in Polished Silver
My D1S's arrived this morning!
Gonna get those suckers in there tonight!
BTW, have you installed them on an M5? Cause i can tell you.. there are much more panels to unscrew than those pictures!! Hahaha.. it's a real pain in the a$$
#48
Great DIY!
Never replaced a xenon bulb before - Guess that the "high voltage" sticker has some effect on me, even though i like to fix things myself (preferably mechanics).
No cables to the headlight is disconnected in the DIY. Do that involve that some risks or did the you remove the minus connector on the battery?
Rgds,
Rasmus
Rgds,
Rasmus
#49
Great DIY!
Rgds,
Rasmus
Rgds,
Rasmus
The reason why the headlight cable is not removed is because of 2 things.
1. if you forget then you will have to remove the assembly all over again to plug it in.
2. There is a trick to removing them. On the big connector you must slide the sleeve to one side until it releases. On the small connector you have to squeeze the tang to remove it.
Make sure to test the headlight before you reinstall the assembly back in the car.
#50
Banned
My Ride: A Car
even if ur headlights are on, if ur careful, ur fine. But I dont recommend it since there are moving components inside the headlight and if u move it too much, things are start breaking.
