rear foglight activation
#41
Looks like it is the same procedure for your car. The wiring diagram is available at this link. Connect position 9 on headlight switch to position 33 on LCM.
http://wds.spaghetticoder.org/en/svg...9470.svg?m=e60
My LCM was black. The blue item in my earlier post is the actual wiring harness which in my case consisted of a blue and brown section that splits apart. You can see the brown section in the upper right corner of my photo. Just identify #33 and drop your wire into the slot.
Good luck.
Just wondering why you need to do this if you are in Germany. Shouldn't your car already have a rear fog?
#42
My Ride: 2006, US Spec, 530i, Silver Gray, Black leather, Anthricite headliner, Steptronic, Navi Pro, PDC, Comfort Seats, Rear Heated Seats, Rear Shades, Folding Rear Seats, Bluetooth w/Blackberrt Torch, AUX Input, Bi-Xenon, AIB Angel Eyes w/matching fogs, summer wheels R118 w/PS2 tires, winter wheels R138 w/Michelin PA3 snows
#43
#44
Got the rear fogs activated. No coding required. All you have to do is run a wire from position 9 on the headlight switch wiring harness to position 33 on the LCM. [url="http://wds.spaghetticoder.org/en/svg/sp/SP0000025822.svg?m=e60"]
Need Euro headlight switch (Has a button for the rear fog light), some wire, and 2 pin connectors. BMW part # 61130006663. [url="http://realoem.com/bmw/showphoto.do?id=61130006663"]
Step 1: I soldered the pin connectors to some 18g wire I had laying around the house. Total length about 36 inches. Attachment 128614
Step 2: Remove the pedal trim panel in the driver's foot well. The trim panel has a light and speaker that need to be disconnected to free up the panel. [url="http://tis.spaghetticoder.org/s/view.pl?1/08/63/52"]
There are 5 screws holding this panel in place. 4 screws are obvious; the 5th one is hidden behind a carpeted trim piece along the driver's side of the center console. Wedge a flat screwdriver between the plastic and carpeted trim piece and rotate the screwdriver to push the carpeted strip backwards to expose the screw. Attachment 128616
Step 3: Remove the original headlight switch by gently prying out and disconnect the wiring harness. This harness has to be disassembled by inserting a small flat screwdriver into this slot to expose the pin connectors. Attachment 128615
Step 4: Identify position 9 on the headlight switch wiring harness and insert one end of your spliced wire connector. It is a perfect fit. Attachment 128617
Step 5: Carefully route the other end of your spliced wire connector through dashboard to the LCM in the footwell.
Step 6: Remove the LCM. [url="http://tis.spaghetticoder.org/s/view.pl?1/08/63/66"]
Step 7: Disassemble the LCM wiring harness. There is a blue and brown subassembly. Identify position 33 on the blue subassembly and insert the other end of your spliced wire connector. Attachment 128618 The connector I bought is not quite right; it has a little flange that you will have to fold over with a pair of pliers. It locks in securely despite this modification. Finally reassemble the LCM wiring harness and reinstall the LCM.
Step 8: Secure the wire to avoid rattles and reassemble the trim panel and install the Euro headlight switch after reassembling the wiring harness.
Step 9: Enjoy your results!!!
Attachment 128620
Attachment 128619
Attachment 128620
Attachment 128619
#46
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
Great write up.
#47
My Ride: '04 530. Black on Black
Black Grills
Tint
Ipod Retrofit June '10
Found something interesting last night. I wired my rear fogs to my front for now, till I get a switch. While out I the country I hit the high beams, and while on I filed the fogs on. Only the rear fog light on the dash went on, as expected, no front fogs with highs. When I killed the highs, the rear fogs stayed on, and the fronts did not come on. I hit the fog button, and the fronts and rears switched, now no rears, and fronts on. Went to the parking lights, and the same was true, the fronts and rears just switched on and off independently, fronts on are off, rears on and visaversa. Apparently the lcm will give some control over what is on when you are in the highs. Not sure if there is a good explanation, or good use for this knowledge, but it is something.
Jay8s
Jay8s
