Reads everything fine, cannot write anything
I'm trying to program an April 2007 E60 with the new DCAM/DCAN selectable USB cable. Connection works fine to the car. I can use INPA to read the stored error code's for instance and erase them. In NCSXPERT, I can read all module's just infe without error. When I program an module (any module) NCSXPERT will finish without any errors, but hasn't actually written my changes at all to any module....? Any tips?
Sounds like your using the wrong profile in NCS. For example, expertmode, while sounding all powerful, will not let you make many changes that will stick.
My Ride: 520i ('04)
+ 1, search the www after Fister or Revtor profile, they are set to code the car. Don't change the settings of the standard Expert pfl, you need it to reset modules to stock.
Oh that could well be the case he only has the Experten Profil!
So I have the REVTOR one in my \NCSEXPER\PFL folder. Can I just email him the file, let him put it in the same folder and it should work?
My Ride: 520i ('04)
Beemer
20
09-16-2004 12:36 PM
