Oil Capacity on 545i
Old 04-04-2005, 04:40 PM
  #21
Guest
Guest
Posts: n/a
Thumbs down
I thought when you the oil on a 545i there's primary drain plug AND a secondary drain plug also?
Also clean out the oil filter holder!
Old 04-05-2005, 05:38 AM
  #22
Mercy's Avatar
My Ride: 2010 550i M Sport Package - Alpine White/Blk Nasca Leather, Premium hi-fi system, Sat Radio, Nav, Cold Weather Package, Value Package, Shift Paddles, Comfort Access keyless entry, Power rear Sunshade, Front Ventilated seats, Split fold-down rear seats, Heated rear seats, Automatic high beams
The filter is a little tricky. You need a 6mm hex socket and a 22 or 24mm wrench, I can't remember which. The 6mm socket unscrews a drain plug in the bottom of the filter housing. You need the wrench to hold the molded nut head so you can remove the drain plug. If you just use the 6mm hex socket, you will loosen the whole housing and oil will go everywhere.
The correct sizes are T40 for filter, T50 for drain plug, and 24mm wrench to hold the filter in place.
I had 3645 miles on mine. I drained 9 quarts of oil out of the pan, I put back 8.5 quarts.
So this would let me to beleive that it was overfilled from factory or the oil started to multiply/grow
Thanks Mehall2, your info was very helpfull.
Old 04-05-2005, 12:33 PM
  #23
Guest
Guest
Posts: n/a
Thumbs up
So is there really a secondary drain plug?
Old 04-08-2005, 06:19 PM
  #24
mehall2's Avatar
[snapback]111535[/snapback]
Unless you consider the one on the bottom of the filter housing, there is No Secondary Drain Plug.
I am glad I could help ya'll out. As I said, next time I will take pictures and post them in a step by step format for all to use.
Safe Driving out there.
Michael "aka" Mehall2
Zimo
04-11-2018 08:25 PM
PelicanParts.com
07-23-2015 12:29 PM
aqualibrium
07-21-2015 03:11 AM
E60GUMSL
07-20-2015 03:45 PM
vards01
07-12-2015 05:33 AM
Quick Reply: Oil Capacity on 545i
