Need a DIY guide on converting a normal E60 front bumper cover to an M
Let me know if there are strings that cover this. I know there'll be a slight gap on each side but want to know if there are steps to minimize the gaps and make it look as cleasn as possible. Also, what do you do about the left and right fog light areas.
ditch the fog lights, M models use those spaces for add'l air to the brakes. No way to mount fogs unless you make a custom fog light housing on the M bumper. Not sure about actual install of the bumper, if it's anything similar to the M-tech bumper, there are a few threads on that. That might be a good place to start.
GL
Gene
GL
Gene
My Ride: G30 M550i
Model Year: 2018
Here are a few threads where the installation of the bumper and prevention of gaps were discussed:
http://forums.e60.net/index.php?showtopic=8626
http://forums.e60.net/index.php?showtopic=45988
http://forums.e60.net/index.php?s=&sho...st&p=746576
http://forums.e60.net/index.php?showtopic=12675
http://forums.e60.net/index.php?showtopic=54559
Here's a link to some .pdf documents that'll help you remove and install things:
http://forums.e60.net/index.php?s=&sho...st&p=326061
Also, here are the .pdf instructions for installing the kit (both the front and rear):
M_Aero_Kit_install_instructions.pdf
socale39
09-05-2023 08:30 AM
chadillac2000
42
09-13-2017 11:15 AM
sweetnlowe60
04-07-2015 01:23 PM
