NCSExpert Code Mods
Old 02-15-2011, 12:21 AM
  #61
kreveta's Avatar
What does this setting does?
BC_DIGITAL_V_KORREKTUR
What's a "true" speed?
Old 02-15-2011, 12:26 AM
  #62
BLooD's Avatar
Added incoming call ringtone to spread sheet. great idea
Old 02-15-2011, 12:28 AM
  #63
kreveta's Avatar
Maybe NoQuarter can stick it on the first post? In a big bold font?
Old 02-15-2011, 12:29 AM
  #64
BLooD's Avatar
Yeah I think it needs to stickied to.
Old 02-15-2011, 04:02 AM
  #65
NoQuarter's Avatar
Engine: N54
Dominik,
If you measure the speed of you car with a GPS you should see your speedo shows a couple kph/mph faster than your true speed. You can get the digital speed to display in the cluster and this setting seems to show a more accurate speed.
Old 02-15-2011, 04:06 AM
  #66
NoQuarter's Avatar
Engine: N54
Getting it stickied is the best bet. This forum doesn't allow us to edit our own posts after X amount of time.
Old 02-15-2011, 04:08 AM
  #67
BLooD's Avatar
Send a message to the admins and see if they will sticky it.
Old 02-15-2011, 04:09 AM
  #68
BLooD's Avatar
Updated some of the confirmed model years.
Old 02-15-2011, 04:10 AM
  #69
kreveta's Avatar
Dominik,
Interesting. However there is some weirdness in GPS speed calculation.
When you turn on the info display in the Navigation info menus, the GPS speed is exactly the same as the speed on your speedometer and your HUD (=incorrect). However if you look at a 3rd party GPS (such as in your phone), then you get a correct measurement with about -5 to -8%.
And so I think the "GPS speed" in Navigation info menu is not true - it just reads the speedometer, doesn't calculate real speed according to satellites.
By enabling this "true" speed in NCS Expert, do you get correct reading in a digital cluster (which is another NCS option) + correct GPS speed in Navigation menus? Does it also affect the HUD reading? I'd prefer to display the accurate true speed everywhere.
Old 02-15-2011, 04:11 AM
  #70
BlaSTiWi's Avatar
BlooD,
No, unfortunately not on pre-LCI only M5 got it right from start of production ... folding mirror only available starting from LCI model on std 5-series.
I swapped by basic mirror (w/ only heat & auto-dip on rev.) w/ M5 mirror w/ all functions so I'll inquiry you for enabling auto-dimming & folding when my cable arrive ...
--RR.
Just a note on the comfort folding, why did you add a date?, did US cars not having folding mirrors right from start of production?
Quick Reply: NCSExpert Code Mods
