NCSExpert Code Mods
Old 01-19-2012, 02:39 AM
  #511
tom_il's Avatar
My Ride: BMW 525dA 2007 pre-LCI.
Originally Posted by Atif_khalid
Is your"VA_CORNERINGLIGHT" set to aktiv in the CAPPL Menu?
Anyone an idea what this should do ?
Which are the cornering lights ?
On my Pre_LCI with halogens I didn't see any change in the iDrive.
Old 01-19-2012, 05:01 AM
  #512
BlaSTiWi's Avatar
It lights up the corner while doing a slow turn for additional safety.
The smaller/inner round reflector of the headlight that has frosted lens (NOT w/ the kind that blank/dark lens)
No not available on pre-LCI model or even on Halogens, it's only on LCI car with Xenon adaptive headlight.
Old 01-19-2012, 05:03 AM
  #513
BlaSTiWi's Avatar
Sorry not related.
Cornering light required AHL (Adaptive) light control.
Old 01-19-2012, 05:07 AM
  #514
BlaSTiWi's Avatar
Sorry, the generic 'heating' understanding maybe correct but the scope was on KGM module more specifically on mirror function (ASP_???) not about the cabin.
My two cents:
STANDHEIZUNG means Parking Heater or Stationary Heater.
Parking heater in the BMW 3 Series Sedan.
The optional remote control parking heater is ideal on cold days. It creates a warm cabin in no time, even if the engine isn't running. The system works by taking energy from the fuel system and using it to warm a water heater. At temperatures below 16 °C, the parking heater can be set to come on automatically at a given time or switched on manually at any temperature.
Old 01-19-2012, 09:16 PM
  #515
Atif_khalid's Avatar
Originally Posted by BLooD
Teleservice enables the car to reports its own service requirements, the dealership then calls you to confirm the booking. Introduced from march 2007 with the LCI production.
Requires settings in both CAPPL and TCUM plus a valid BMW Assist account is needed for Teleservice to function.
Add $6AA Teleservice and $6AB Teleservice control to the VO.
CAPPL:-
TELESERVICE aktive
TDA_ASC_STATUS aktive <- Auto sercive call status in CBS menu.
TDA_BDA_STATUS aktiv <- not sure on this one.
TDA_CFG_AUTO_TRIG aktiv <- not sure but could be linked to ASC.
TDA_CFG_CUST_MOBILE_USE aktiv <- this should be enabled by default.
TDA_CFG_HLC_DATA aktiv or night_aktive <- Teleservice hotline call, mine is off as i don`t need it.
TDA_CFG_IND_PDM_GR_NBR file0 <- not sure for this one, file0 is default.
TDA_CFG_SER_ERR_SINK aktive <- default is aktive.
TDA_CFG_VEHICLE_SER aktive <- linked to vehicle service data.
TDA_DEACTIVATE_STATUS aktive <- allows deactivation of the Teleservice system.
TDA_HLC_STATUS aktive or nicht_aktive <- shows the status of the Teleservice hotline.
TDA_MSC_STATUS aktive or nicht_aktive <- shows the status of the Teleservice mobile service.
TCUM :-
AUTO_SRVC_CALL aktive <- enables the car to make it`s own service calls.
AVAIL_SERVICES_REPORTING long <- not sure what this does but mine was set to short.
NEW_MYINFO_LOC aktive <- LCI Assist my info.
TDA_BDA_STATUS
AUTO TRANSM W/DOUBLE CLUTCH STATUS IN CBS MENU
Old 01-19-2012, 11:45 PM
  #516
Then probably for heating of side view mirrors.. my coding cable has gone bust so am waiting for a new one and once it arrives, I will let you know what this does.
Old 01-20-2012, 01:05 AM
  #517
Regarding welcome lights and path way lighting, I have the following options activated:
DEF_WELCOMELIGHT_CKM aktiv
UNP_WELCOMELIGHT_CKM aktiv
VA_WELCOMELIGHT aktiv
WELCOME_LIGHT aktiv
WELCOME_LIGHT_ACTIVE aktiv
WELCOMELIGHT aktiv
WELCOMELIGHT_CKM_0 aktiv
WELCOMELIGHT_CKM_1 aktiv
WELCOMELIGHT_CKM_2 aktiv
WELCOMELIGHT_CKM_3 aktiv
WL_DAUER wert_01 (Length of time they stay on)
WL_KZL soft_einschalten (Rear license plate lights when unlocking the car) ------ yet they dont blink or turn on when locking/unlocking
WL_MAX_DAUER wert_01 (Maximum duration for welcome lights)
WL_NSL soft_einschalten (Rear fog lights on when unlocking the car) ------ yet they dont blink or turn on when locking/unlocking
WL_POL aktiv (Corner LED on when unlocking the car) ------ they blink once/twice when locking/unlocking respectively
WL_SL_1 soft_einschalten (Angel Eyes on when unlocking the car) ------ yet they dont blink or turn on when locking/unlocking
WL_SL_2 hart_einschalten (Front Parking lights on when unlocking the car) --------- yet they dont blink or turn on when locking/unlocking
WL_SM soft_einschalten (Dont know what this is)
WL_ZYKLEN wert_01 (Welcome lights cycles) ------ nothing happens
In the Idrive menu, welcome lights box is also checked!
Where am I going wrong?
Old 01-20-2012, 01:21 AM
  #518
tom_il's Avatar
included my Trace file. I have the welcome lights working. (front fog lights, AE and most of the rear lights).
However nothing in idrive. Did the doing Cappl though.
What also doesn't work with is switching the lights on with the truck button on the key.
you need to have the light switch on AUTO for them to work.
File Type: txt
Old 01-20-2012, 01:30 AM
  #519
BLooD's Avatar
Works on mine BlastiWi and mine is pre-LCI.
Old 01-20-2012, 01:58 AM
  #520
tom_il's Avatar
Interesting. Do you have Xenon's ?
What wonders me is that there is no coding required in the LM module for the cornering lights (or at least none that i know off), only in cappl .
Also on my car with halogens the inner lights are the high beams. Surely they arn't used as cornering lights. More logic it would be that the fog lights would be used as cornering lights as in most cars today.
Quick Reply: NCSExpert Code Mods
