NCSExpert Code Mods
#421
My Ride: 2007 Black Sapphire 535i
I made an Exciting discovery tonight that I would like to share with you guys. I recently swapped my Lexani wheels out for my OEM tires so that I could get my Lexani's powder-coated in black. Once I did this I got the pesky Flat Tire error TPMS message in iDrive. When I tried to reset the error I would always be faced with a menu screen with the "Reset" option greyed out meaning that the option was disabled. I drove around with the damn error for weeks until I re-installed my Lexani wheels this week and was determined to get the error cleared.
After trying everything else and since I am using an E90 CIC TRC file to program my CIC I wondered if this option was disabled in the original file by default and was something I had to enable. After searching the file repeatedly and trying different coding options for a few hours, I found the culprit!!
Within the CIC TRC file these two lines of code are enabled and need to be disabled:
Once these lines are disabled, the "RESET" option within the Flat Tire iDrive menu screen was re-enabled and I was successfully able to reset the sensor, hence clearing the error. Happy Day!! Hopefully this will serve to help others.
Cheers!
Code:
RDC aktiv -> Change to nicht_aktiv RDC SAFETY aktiv -> Change to nicht_aktiv
Cheers!
#422
My Ride: Many BMW's
i'm not sure about other countries , but all BMW cars in our country doesn't have TPM sensors inside the wheels ,,,
the car uses the ABS/DCS wheel sensor to measure the rotating speed of each tire , if one tire rotates faster or slower than what is supposed to be ,, tire pressure error pops up on the screen ..
I've upgraded to bigger wheels several time ,,all I did after the upgrade it set it up again like what is shows in your screen above ,, and you are good to go ..
#423
The only problem was that since I upgraded my CIC with the E90 file, my option to reset the tire error was disabled. Changing the code above gave me the ability to actually use the reset functionality.
#427
It's in DWAS module:
BUZZER_HIGH_LEVEL
wert_06
wert_07
wert_08
But some say highest volume is achieved by leaving wert_01 only, others say wert_08 only or even a combination like this
wert_04
wert_05
wert_08
So does anybody know the correct parameter for the highest possible sirene volume?
There is even a parameter BUZZER_LOW_LEVEL with the same possibilities...very confusing, for me at least.
BUZZER_HIGH_LEVEL
wert_06
wert_07
wert_08
wert_04
wert_05
wert_08
#429
My Ride: 525i M54 2005 Alpine White
Sport/Cold/Premiun Sound/Active Steering
Navigation/PDC/sport seats/6 CD Changer
Hey, Can someone point me to the right direction? which interface is best for me to get, that's compatible with my BMW 525i 2005 M54 ![Confused](https://5series.net/forums/images/smilies/confused.gif)
Ebay BMW Adapter Link
#430
My Ride: 94' 325i(sold), 01 530 spt (sold) 08 528i
Should the inner-side halogen light of each headlight light up when cornering? Or what is its function? This one - the inner which is not lit up on the picture:
![](https://www.umnitza.com/images/e60frontlightonsm.jpg)
Mine started to turn on/off when cornering slowly, parking or backing up. I've never noticed it happening before switching PWM_AN_SL_V_AL_1_34 from wert_06 to wert_01.
Any one answered this question?.. i just noticed that myself tonight.
