NCSExpert Code Mods
Old 05-28-2011, 08:11 AM
  #351
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
CAS.
Old 05-28-2011, 09:02 AM
  #352
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
Originally Posted by bmwfive
Are you coding CAS>RLS or LMA>RLS?
The only reason I ask is because I have done previous coding to bulb checks under CAS>LMA and this also didn't work. (I have been successful with the digital speedo, so coding is working)
What car do you have? Are you using a correct profile? Did you really confirm the changes by reading the unit again?
It is really interested.
Old 05-28-2011, 09:53 AM
  #353
bmwfive's Avatar
e60 530d msport (2004)
I set up NCSExpert using a guide (based on the e90) so not sure about profile, but coding works as I have the digital speedo working.
Yes I definitely confirmed the changes by reading the unit again.
Old 05-29-2011, 09:32 AM
  #354
kreveta's Avatar
Should the inner-side halogen light of each headlight light up when cornering? Or what is its function? This one - the inner which is not lit up on the picture:
Mine started to turn on/off when cornering slowly, parking or backing up. I've never noticed it happening before switching PWM_AN_SL_V_AL_1_34 from wert_06 to wert_01.
Old 06-03-2011, 09:50 AM
  #355
marv's Avatar
Hi Guys. I have retrofit my BMW e60 in CCC (before I had the MASK on a board). After that mulf module doesn't want to read a phonebook from my iphone 4. Do you know what I should code in CAPPL or different module to read phone book again ? Before retrofiting everthing was ok... In CAPPL I have TELEFON_TYPE_C08 with mulf_phone value. And iPhone is paring with my bmw but I can't sync the phonebook
Old 06-03-2011, 04:36 PM
  #356
AI001's Avatar
Sometime ago I installed a amp kit in my car (Alpine PDX-5), is it possible to selectively reduce/increase some sound level.
I want warning "dongs" and pdc alert (front and back) to reduce in volume and nav guide to increase a bit.
Not seeing this coding option before I had to live with reduced volume on everything, wish I could control it selectively.
Old 06-04-2011, 12:46 AM
  #357
madein's Avatar
Model Year: 2011
I had very similar problem, and after software update it was sorter, just check the version of the software you have in CCC and MULF.
Old 06-04-2011, 12:47 AM
  #358
madein's Avatar
Model Year: 2011
Any luck?
Old 06-05-2011, 08:21 PM
  #359
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
I did the Flashing adaptive brake lights (Break Force Display) In an emergency stop flashing the lights (like the Hazard lights).
http://www.youtube.com/watch?v=Ql4Kd-plRJM
This should be better with the double blink hazard NETTO coding (need to redo, got erased again :thumbsdown: ).
Old 06-05-2011, 08:34 PM
  #360
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
One more. Flash to Pass, using the xenon instead of the halogen (default).
BI_XENON_BEI_LH aktiv
http://www.youtube.com/watch?v=VzzXunZMynE
Quick Reply: NCSExpert Code Mods
