NCSExpert Code Mods
#321
2005 545.....
Windows up works
Fan display works
Skip weather band works
Skip AM works (with what I added above)
Windows open by key without sunroof works (KOMFORTOEFFNEN_FB_O_SHD in CAS)
Pressing "auto" does not turn on AC works (ABWAHL_AC in ihka)
Digital speedo worked on my 05 525
Double blink hazards (really want double blink turn signals)
I'm sure there is more after I think about it more.
#323
I have a 2005 E60 and also got everything that is listed here, except for the HUD (don't have it). For the windows to rollup with the keyfob, I had to enter the text for it. I copied the similar line and added _FB, and it worked.
I do have a question. On the two temperature dials, are there lights that are supposed to show? I have a light for the fan speed, but the temps are nothing.
Any idea on what the entry would be?
I am new to coding but learning fast. I have to temper my ambition so I don't do any harm! I think I have done the changes I want, but will continue to learn. This thread has been a huge help!
Thank you,
Tom
2005 545.....
Windows up works
Fan display works
[/quote]
Thank you,
Tom
2005 545.....
Windows up works
Fan display works
[/quote]
#325
Thank you.
It seem strange that there are no indicator lights for the temperature. It's kind of just "turn it up if you're cold, turn it down if your hot"
It almost looks like there should be lights because they look identical to the fan speed knob.
Oh well........
I'm not done looking into this and if I find anything of use, I'll post it.
Happy Memorial Day and pray for the people of the Midwest effected by the tornados.
Oh well........
#327
My Ride: BMW E60
Model Year: 2016
I think you should not have polluted this thread and started a new one. With that said, a lot of these look like coding issues regarding your LCI conversion. The sun roof you can try to reset it on your own.
#328
Well when I started my car this morning mview worked for about 30 seconds without me touching anything. Had the rpm bar with what looked like a very low redline but had no numbers as to what rpm was what. Switched itself off but still shows active in the idrive menu. I want to get it to work just for proof of concept on an 05 but probably won't keep it as I want my second steering wheel button back.
#329
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
It is happening to most of us, you will need the M5 cluster to have it permanently.
#330
Model Year: 2011
