NCSExpert Code Mods
Old 05-16-2011, 10:11 AM
  #281
jay77's Avatar
Originally Posted by madein
Hi Blood it is amazing
just did it on mine - only differences is I have LMA 1 and the sentence: "B 00340500,0010,95,71,00,83,0A,00,51,00,14,53,01,15, 59,04,00,00" was slightly different, just changed the value of 95 to 97 and it is working perfectly.
Did you compare the FSW files after coding?
The only differences I can see is than the:
BLINKIMPULS_WARNBLK wert_01
disappeared from the new FSW trace file.
In this case just maybe delete this from the FSW and code it as usually do the job?
This may do the job for the rain sensor sensitivity as well on the Idrive menu?
Even maybe welcome lights for LMA1 owners?
Definitely looks like you opened a "PANDORA BOX" for all of us E60/61 owners.
re: welcome lights on a LM1, It would be interesting to compare the trace file of a LM2 and LM1 to see if coding other options is possible, but I get the impression there will be a different number of values available between the two, hope Im wrong, but it will need a comparison of the two and knowing what value determines the welcome light (Easy enough to find I guess if you do a before and after comparison on a car with welcome lights..hint hint )
Old 05-16-2011, 12:43 PM
  #282
BLooD's Avatar
You can not add functions that dont exist in the modules programming, Thats the correct behaviour madein, the tracefile can not show the new paremeter.
I need to say a huge thanks to Revtor over at bimmerforums, with out him de-coding the LMA2 nettodata i would never have sussed this out.
Old 05-16-2011, 01:02 PM
  #283
madein's Avatar
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I know, I know, but still don't give up.....,
I remember you said once the double hazards are not possible also.....
I'm just wondering, if deleting the "BLINKIMPULS_WARNBLK wert_01" will do the same job, I may try this during the weekend....
Old 05-16-2011, 06:29 PM
  #284
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Mine too was different, but I just changed to 97 as well and it works.
Will have to see when I have time to figure out the other two hex codes. (didn't someone wrote up a converter somewhere?) The blinking rate, I am certain, is not the same as the E9x's. Their blink rate is a bit more "elegant" to me.
Regardless, this is a great step forward!
Here's my quick vid:
http://www.youtube.com/watch?v=7gLmpSdvViA
I will take another one when it gets darker, should be easier to see.
Old 05-16-2011, 09:01 PM
  #285
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
in the order to chance pre lci to lci...do u need lm1 or lm2?
looks like i did the swap but i still got lm1 for lci..!!
Old 05-16-2011, 10:26 PM
  #286
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
wut.
Old 05-16-2011, 11:04 PM
  #287
BLooD's Avatar
Revtor tells me that the next version of NCSdummy will support nettodat manipulation, so thinks are gonna a whole lot more interesting very soon. Watch this space!
Old 05-16-2011, 11:17 PM
  #288
madein's Avatar
Model Year: 2011
Is than nettodat different than fsw? It may have more options, but any changes in nettodat we should be able to see in fsw?
Old 05-16-2011, 11:58 PM
  #289
BLooD's Avatar
The nettodat is the module functions in hexi-decimel data, by changing the nettodat your changing the module coding data at the programming level. The FSW file can not show non-standard coding values.
Old 05-17-2011, 06:45 AM
  #290
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
wut.
what i am talking,,is..that i did lci retrofit...and i thought that when u do that,will only work with LM2 ...but seems that retrofit can be done with the old LM1..
Quick Reply: NCSExpert Code Mods
