NCSExpert Code Mods
#161
#162
Thank you, NoQuarter (Jim) for providing your CAPPL trace file to compare.
It turns out that it's the switch in HUD trace file was not set correctly.
Mine now shows gear in manual mode, N and R.
However, when I first switch to DS, I cannot downshift. When I upshift, it's M2. This is different from what normally is. Not sure if setting MDRIVE_SMG from "aktiv" to "nicht_aktive" cause the issue?
Will look into that tomorrow.
Cheers,
Fred
Cheers,
Fred
#163
My Ride: 535d -08 lots of goodies
120dA -06
I recently replaced my brake bulbs with LEDs, and now im trying to remove the bulb checks, but the car is fighting me harder then i thought it would,
From the LMA module,
KALTUEBERWACHUNG_BL_L
nicht_aktiv
KALTUEBERWACHUNG_BL_R
nicht_aktiv
KALTUEBERW_RL_BL_1_L
nicht_aktiv
KALTUEBERW_RL_BL_1_R
nicht_aktiv
WARMUEBERWACHUNG_BL_L
nicht_aktiv
WARMUEBERWACHUNG_BL_R
nicht_aktiv
WARMUEBERW_RL_BL_1_L
nicht_aktiv
WARMUEBERW_RL_BL_1_R
nicht_aktiv
FEHLERMELDUNG_CC_BL_L
nicht_aktiv
FEHLERMELDUNG_CC_BL_R
nicht_aktiv
FEHLERMELD_CC_RL_BL_1_L
nicht_aktiv
FEHLERMELD_CC_RL_BL_1_R
nicht_aktiv
With all this removed, it still produces and error, any hints?
Full trace avalible here should it be needed.
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
#164
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Member
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
![Hyper](https://5series.net/forums/images/smilies/imported/hyper.gif)
We shall wait for his finding info ...
#165
My Ride: 2012 535i M-Sport
To keep LCI (maybe pre-lci also??) AE's stay bright:
Go into LMA and look for:
PWM_AN_SL_V_AL_1_34
wert_06 - ** Change to wert_01 **
Sorry I made a new thread about it - got too excited, haha.
I am real curious how this will change the look at night for those running LED LCI AE's.
PWM_AN_SL_V_AL_1_34
#166
Spreadsheet updated!!!
Great Job Chase!!!![Clap](https://5series.net/forums/images/smilies/imported/clap.gif)
Great Job Chase!!!
PWM_AN_SL_V_AL_1_34
PWM_AN_SL_V_AL_1_34
#167
I had an SOS System Malfunction Error that I could not clear- even with INPA. The bluetooth functionality was still working fine. I tried the published trick of deleting the phone from the car (and the car from the phone) and then reestablishing the bluetooth connection, but the error would keep appearing at start-up.
I changed the value of E-CALL_HARDKEY_FITTED in the TCUM module to nicht_aktiv. I turned off the key, waited for 10 seconds and when I turned the key back on the error code was cleared and I no longer had the error. I didn't have an account anyway I and I don't plan on getting an account so the functionality isn't something that I'm going to miss. It sure beats going to the dealer and getting a new module installed!
#168
120dA -06
I can have a go with the bright AE at night in a little while, but i really need some input on how to disable the rear brakelight warnings on LCI cars.
#169
My Ride: BMW E60
Model Year: 2016
If anything, you can apply resistors and you'll be fine.
#170
Oh, and we should also add to the google doc that turning off the amber eyebrow is:
LMA
SIDEMARKER_US
nicht_aktiv
I did this out of curiosity and it turns out I like the way it looks better.
Just to goof around I am going to turn the eyebrow into my front turn signal...might look awful, but fun is fun.
LMA
SIDEMARKER_US
nicht_aktiv
