NCSExpert Code Mods
#151
Fred,
Try to check and see what you have for ASP_BEIKLAPPEN in the KGM module, I have to make it aktiv even after adding SA430 then my M5 mirror will fold.
AFAIK enabling BEIKLAPPEN_B_KOMFORTSCHL function just link the folding ability to the fob but US model still need to know the mirror has folding motor.
https://5series.net/forums/topic/108...st__p__1311766
Give it a try GL!
PS: Just not sure if your build year still using door module or not, if yes try in TMBT & TMFT modules maybe.
--Rival.
Give it a try GL!
--Rival.
Working on folding mirror, but it is probably due to model year in US that does not support folding mirror although I have SA430 in FA list. I added SA313 from FA list provided earlier in this thread, but it's invalid. Not sure what to do next. Should I change the build date?
Cheers,
Fred
Cheers,
Fred
#152
It's working
Thank you BlaSTiWi!!!!!
As for LCI tail light:
I disabled bulb checks and I made simple wiring similar to Ricky's effect wire and it works perfectly.
I'm pretty much done with my NCS Expert mod. What else?
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
![Hyper](https://5series.net/forums/images/smilies/imported/hyper.gif)
#154
#156
#159
Engine: N54
#160
