NCSExpert to code Bluetooth?
I have recently bought a second hand bluetooth TCU, and am now trying to add +k633 and $639 to the VO (via NCS Expert)
Whenever I attempt to do so, I am met with the following error message:
ERROR! Modul: CVT_PROC.C, ProcNr: 02, LineNr: 10, ErrorNr: 106.
TELEFON_TYPE_APP
ERROR! Modul: COAPI.CPP, Proc: coapiGetFswPswFromAsw, LineNr: 02, ErrorNr: 1000
COAPI-1000: error
Has anyone experienced such an error before?
Steps to replicate error:
1. Load Expertmode profile in NCS Expert
2. Select CHASSIS (F2) and then E60
3. Select VIN/ZCS/FA (F1)
4. Select ZCS/FA f. ECU (F3) and select CAS
5. Select Enter FA (F2) and select E60. VIN number then prepopulates
6. Add +k633 into the Attribute field (the CHASIS field is already prepopulated with the value E60_)
7. Select OK
8. Select Back (F6) and error message appears
Additional Information
- I have an 06/04 E60 525i with CCC Professional Nav / SA640 option
- My VIN Number is B572676
- If it makes any difference, I previously had an aftermarket bluetooth module installed, however when clicking the Communications Tab within my iDrive, a "Telephone from other manufacturer installed" message appears.
- I have already tried using a blank FSW_PSW.man file, still no luck
- I have been successful in adding $605 to the VO. I only seem to be having issues whenever I try to add +k633 and $639
- Given that I have Voice Control and the SA640 option (without BMW Assist), I assumed that all that was additionally required was a TCU and mounts. I have not purchased any additional items.
Any assistance would be greatly appreciated.
Thanks
TELEFON_TYPE_APP
COAPI-1000: error
7. Select OK
Thanks
My Ride: 530i E60
I'm trying to do this as well.
First, I don't seem to have $605 or $639 in the option order. When to write to TCUM I don't have this module listed either, even after adding +K633 to CAS module.
Any ideas? Do you need to have a certain profile or files?
Rudy
Bluetooth & Cell Phone Forum
May 10, 2005 06:18 AM
