NCS Expert on windows 8 64-bit?
My Ride: 2005 525i
Can I set up NCS Expert on my windows 8 laptop? If so any help would be appreciated. Thanks in advance.
My Ride: 2005 525i
Thanks for that, I found my old laptop that is windows xp and decided to install it there instead. I'm also getting an error when I try to add something to my VO (Vehicle Order). If anyone is willing to help me out I can post the error logs. On a side note is this the correct place I should be posing about this topic?
My Ride: 530i
Engine: M54
Post up the error logs, I'll see if I can help. I'm comfortable using BMW Tools, but if we can't solve your problems here I'd suggest signing up for bmwcoding.com's forum and searching there. The people on that forum are pretty advanced as far as troubleshooting software goes.
Post up the error you're getting.
My Ride: 2005 525i
This is most definitely the right spot to be posting this!
My Ride: 530i
Engine: M54
What is the production date on your car?
I'm wondering if you have the right cable. There are two versions, DCAN and KCAN. some cable will only work with one or the other, some will do both. The difference in the cables is whether or not pins 7 and 8 are bridged together. Make sure you are using the correct cable for your car.
Wonky
04-12-2016 08:15 PM
