NCS EXPERT Radio Frequency coding /programming Australia, Europe, Japan , USA .
Hi all , I am going to show you how to code with NCS Expert and our task will be to setup the radio frequency of your BMW . This video will be very helpful for those of you who import bmw cars from USA, Japan, Europe. For example - the FM broadcast 📻 in the United States starts at 88.0 MHz and ends at 108.0 MHz. The band is divided into 100 channels, each 200 kHz (0.2 MHz) wide. In that case their FM frequency starts from 88,1 Mhz going through 88,3/88,5 and so on.. with 0,2Mhz interval in between. In Europe the wide interval should be 0,1Mhz for example 88,0/88,1/ 88,2/ 88,3/ .. and so on..
We are going to code CAPPL and CTUNE ecu's in NCS Expert. ENJOY watching the video below👇👇👇 !
KKDriver
DIY: Do It Yourself
12-24-2021 12:38 PM
