Mobil 5w30 or 0W40?
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish.
Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
I change the engine oil in my 04'530 every 7500 miles. I have been using Mobil 1 5W30 for the last 3 times..but someone suggested I get the 0W40 instead.
My questions:
- is there any benefit changing to Mobil 1 0W40?
- also, does everyone here change the 2 small o-rings in the oil filter housing at every at change, apart from the larger o-ring? I am using Mann filters.
thanks
~ V
My questions:
thanks
~ V
I just switched to 0W40, Its recommend by BMW since it meets BMW requirements. So I would go with 0W40 European formula
Here is what it says in the manual:
The oils listed below meet BMW?s Long-life rating and are acceptable for use in BMW
Passenger vehicles and SAVs in the US market with gasoline engines.
BMW Long-life rating LL-01
Approved Synthetic Oils for the US Market:
Castrol Syntec European Formula SAE 0W-30
Mobil 1 SAE 0W-40
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
Mobil 1 SAE 0W-40
M1 5w30 is not BMW LL-01 rated and therefore should not be used in our engines. The newer formulation of that oil is not very good anyway, I have personal experience from running it in Japanese cars in my family, I'm not running it anymore. M1 0w40 is a MUCH more stout oil with a much better base stock than the 5w30, use it without even looking back
I personally use M1 0w40 in my car now and will do an oil analysis soon to compare it to the Castrol Syntec 0w30 I used before. That's also a very good oil - sold in PepBoys and Autozone.
My Ride: E60 530i
Engine: M54
I used M1 5W30 every 5000 miles, no problem so far. I don't see any bad effect, can anyone list the bad effect using M1 5W30 ?
My Ride: 2006 BMW 550i
mobil's 0w-40 is closer in spec to bmw's 5w-30 oil. mobil's 30 weight oils are on the thinner end of the scale.
My Ride: E60 530i
Engine: M54
My Ride: 05 545i 6MT
Would you post a new thread for this comparison?
I've been using German Castrol European 0W-30 and wondering how Mobil 0W-40 European compare to GC
boozooface
Bluetooth & Cell Phone Forum
07-29-2015 06:56 AM
