M5 Front Brakes
My Ride: 545i Sport
Engine: N62
1. Chock rear wheel and lift the front after loosening the wheel bolts.
Remove wheel (ensure 19" rim or bigger for right fit)
I have an OEM M166, so no problem here
Remove 2 Hex bolts to remove caliper housing.
![M5 Front Brakes-step1.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27069d1482364638t-m5-front-brakes-step1.jpg)
Unscrew inner hex bolt to remove brake disk.
2. Pull out brake pad wear sensor(Present only on left side).
![M5 Front Brakes-step2.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27076d1482364638t-m5-front-brakes-step2.jpg)
Note: Do not pull the cable, grasp the sensor(green) firmly and pull out.
3. Remove brake line from old caliper housing and install to the M5 caliper housing.
I rotated the housing to prevent hose from getting twisted.
![M5 Front Brakes-step3.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27070d1482364638t-m5-front-brakes-step3.jpg)
4. Install M5 rotor using single inner hex bolt.
![M5 Front Brakes-step4.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27071d1482364638t-m5-front-brakes-step4.jpg)
5. Install M5 caliper using 2 hex bolts.
![M5 Front Brakes-step5.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27072d1482364638t-m5-front-brakes-step5.jpg)
6. Re-install wear sensor
![M5 Front Brakes-step6.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27073d1482364638t-m5-front-brakes-step6.jpg)
7. Bleed the system. You need another body for this.
![M5 Front Brakes-step7.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27074d1482364638t-m5-front-brakes-step7.jpg)
Note: Bleed right side then left side.
8. Ensure all bolts are properly torqued then install the wheel, applying proper torque to the wheel bolts.
![M5 Front Brakes-step8.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27075d1482364638t-m5-front-brakes-step8.jpg)
Next: Brake Fluid Reservoir Access
My Ride: 545i Sport
Engine: N62
To access the brake fluid reservoir located under the Cabin Air Filter Left housing.
1. Lift(the one I'm pointing at) and slide to the right to remove.
![M5 Front Brakes-stepa.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27082d1482364638t-m5-front-brakes-stepa.jpg)
2. Remove filter housing.
![M5 Front Brakes-stepd.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27077d1482364638t-m5-front-brakes-stepd.jpg)
![M5 Front Brakes-stepe.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27078d1482364638t-m5-front-brakes-stepe.jpg)
3. Rotate CCW.
![M5 Front Brakes-steph.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27079d1482364638t-m5-front-brakes-steph.jpg)
![M5 Front Brakes-stephh.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27080d1482364638t-m5-front-brakes-stephh.jpg)
remove this rubber piece.
4. Lift rubber seal and move aside.
![M5 Front Brakes-stepi.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27081d1482364638t-m5-front-brakes-stepi.jpg)
5. Unscrew torx screw.
![M5 Front Brakes-stepii.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27083d1482364638t-m5-front-brakes-stepii.jpg)
6. Lift and voila!
![M5 Front Brakes-stepg.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/27084d1482364638t-m5-front-brakes-stepg.jpg)
Use DOT 4 Brake fluid.
3. Rotate CCW.
6. Lift and voila!
My Ride: 545i Sport
Engine: N62
Originally Posted by my530i' post='371327' date='Dec 26 2006, 08:36 PM
Great! Thank you very very much!
Did you feel brake performance increase dramatically?
Thanks
Thanks
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Way to go Rizbel!
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
You're now officially mod-addicted ![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
Waiting for another DIY
You might need spring compressor and air wrench to turn spring compressor to compress those springs.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
Good luck on your project!
My Ride: 545i Sport
Engine: N62
Good luck on your project!![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
install.
The steering wheel paddle shifter is still on my wish list though
