LED H7 as DRL
Old 11-04-2009, 03:24 PM
miguex's Avatar
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
Hello, I just want to post this thread for few members who pmed me regarding about DIY for swapping the OEM bulbs (High Beam or H7) to LED bulbs.
So here are few pictures:
What you need: (you can purchased them in Ebay)
1) 1 Pair of LED H7 Bulbs (with 18 leds or more per bulb) I am using with 18 leds in one H7 bulb.
2) 1 Pair of Resistor (6 Ohms - 50 Watts)
3) Connectors for cables.
3) Optional: Any wire of 16 or 18 gauges if your resistors didn't come with wires inserted.
Picture #1 & #2 (wire and 2 resistors) you can buy resistors with wires on but in my case they didn't so I had to solder them.
Picture #3 (the connector and just 4 ones are needed)
Picture #4 & #5 (Note: Important here there are 3 wires: you need to connect the white one and the thick brown (not the thin brown)
Picture #6 (you may need to cut a hole to allow the wires go out)
As you see Why it has a long wire and out? Cause the resistor can burn on the plastic so it is good idea to take them out.
FINAL PICTURE with the LED H7 installed.
ENJOY!
Old 11-04-2009, 03:31 PM
EV4530's Avatar
Nice work Miguex
Old 11-04-2009, 03:32 PM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Thanks for the DIY! I will be looking into this =)
Old 11-06-2009, 10:57 AM
rictor's Avatar
Any error codes or does the resistor take care of that?
Old 11-06-2009, 07:07 PM
Banned
John@Motorcepts's Avatar
My Ride: A Car
resistors take care of the error codes.
You wouldnt need to splice the factory wires. Take the cap from the socket OFF and then twist the connections on.
Old 11-07-2009, 07:00 PM
miguex's Avatar
the resistors are the solution for the errors.
Old 11-07-2009, 07:02 PM
miguex's Avatar
yes that is true! that is another option! thanks Brasbus!
Old 11-12-2009, 10:17 AM
rictor's Avatar
Much better than splicing!
Miguex,
Can you take some daylight pictures up close with the bulbs off and on? I'm curious as to how much detail you can see or if you can tell it's not a "normal" bulb.
Old 11-24-2009, 11:34 PM
pinguhk's Avatar
My Ride: Mini Cooper
have you any photos of the final diy on how it looks.
Old 12-01-2009, 06:29 PM
cleung's Avatar
this is a cool mod,
what happens when you try to flash your highbeams?
bestofthebest
03-28-2016 02:47 PM
juji126
11-03-2015 10:53 PM
bestofthebest
10-02-2015 03:21 PM
Bogdan7
09-23-2015 11:40 AM
Quick Reply: LED H7 as DRL
