iPod Hardwire Install
Banned
I wanted to connect an iPod to my car and decided that waiting for the BMW iPod connector might take a while...or never happen, so I got the aux input installed ($64 part + $140 install). They also updated my s/w to 17.01.
I decided to have the iPod in the center arm rest (to be out of sight, and also have easy access).
For a power source, I went with the Monster iCarCharger, since it has a direct line out (not through an amplifier like the Belkin adapter, so you have a clean output), which I hardwired to the switched power lines of one of the power outlets in the rear center console (below the A/C vents). You definitely don't want to use the headphone jack, since it is filtered and tailored toward headphone use and the quality & volume level of a headphone simply cannot compete with your car stereo. The headphone jack sound quality and bass levels are greatly reduced. The bottom dock connector (which transfers audio out of the iCarCharger's 3.5mm port) generates pure, unfiltered sound.
Here's a list of parts you'll need--on a difficulty scale of 1 - 5 with 1 being the easiest, I'd say this DIY is a 3--once I had all the parts, it took me half an afternoon to complete:
Monster iCarCharger--$40 from BestBuy:
![iPod Hardwire Install-icarcharger.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8300d1482363340t-ipod-hardwire-install-icarcharger.jpg)
http://www.monstercable.com/computer/produ...pple%20Products
Monster MP3 MusicConnect shielded cable with mini-stereo connectors (1/8" mini jack on each end)--$20 from BestBuy:
![iPod Hardwire Install-mp3_musicconnect.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8301d1482363340t-ipod-hardwire-install-mp3_musicconnect.jpg)
![iPod Hardwire Install-mp3_musicconnect_2.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8302d1482363340t-ipod-hardwire-install-mp3_musicconnect_2.jpg)
http://www.monstercable.com/productPage.asp?pin=3258
Griffin AirClick remote control for iPod--$40 at Apple Store:
http://www.griffintechnology.com/pro...lick/index.php
Wire connectors--$4 at RadioShack:
http://www.radioshack.com/product.asp?cata...ct%5Fid=64-3131
http://www.radioshack.com/product.asp?cata...ct%5Fid=64-3133
18 gauge wire--you?ll need about a foot--I bought 4 feet to have extra ($0.12 per foot)
In-line fuse holder & fuses--$5
With this set up, when you have the audio input on aux input and the iPod playing & you turn off the car, the iPod pauses and shuts itself off after a few minutes. When you start the car, the iPod turns on and is still paused (at the point in the song when you turned off the car), and I use the Griffin AirClick to resume playing, by pressing the play/pause button (actually, pressing any button will work). I keep the AirClick remote in the drivers door storage area, so it's easy to press the play button. You don't have to open the center arm rest to access the iPod, except when you want to select a new playlist.
I first removed the coin holder in the center arm rest--there are 4 torx screws (red circles)--you can see the coin holder on the seat (yellow circle):
![iPod Hardwire Install-1_coin_holder_removed.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8304d1482363340t-ipod-hardwire-install-1_coin_holder_removed.jpg)
Next remove the panel that holds the 2 power outlets at the back of the rear center console--I used a metal spackle knife to wedged it out from the bottom sides--you need to use a bit of force, and it will eventually snap out on both bottom sides. Here's instructions (compliments of Rudy
rear_insert.pdf
The 2 clips on the bottom sides (red circle) fell into the center console so you need to find them with a flash light and replace them for reassembly. The pic also show the 2 clips from the bottom edge of the A/C vent (yellow circle--see next instruction).
![iPod Hardwire Install-2_bottom_panel.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8307d1482363340t-ipod-hardwire-install-2_bottom_panel.jpg)
Next you remove the A/C vent--instructions:
fresh_air_grill.pdf
There are 2 clips (yellow circles) at the bottom corners, which you use needle nose pliers to pull down and out, then you pull the assembly toward you and down to remove. The red circle shows a blue female connector which I connected to the green wire in place of the stock connector, to fit the harness I made:
![iPod Hardwire Install-3_console_wires.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8305d1482363340t-ipod-hardwire-install-3_console_wires.jpg)
To hardwire the Monster iCarCharger, I used the metal spackle knife to wedge open the part of the adapter that would slide into the power outlet, to reveal the spring in the center, and one of the metal pieces on the side. I attached a female connector to each and crimped to secure (red circle). The pic also shows the line out connection (yellow circle):
![iPod Hardwire Install-4_connections.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8306d1482363340t-ipod-hardwire-install-4_connections.jpg)
I assembled a harness to tap into the power and ground wires from one of the rear power outlets. The blue male connectors at the far right connect to the female connectors that originally connected to the power outlet (the red circled connection is unnecessary--you can use a straight wire here). The orange female connectors (yellow circles) connect to the power outlet:
![iPod Hardwire Install-5_harness.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8314d1482363340t-ipod-hardwire-install-5_harness.jpg)
Wrap all exposed connections with electrical tape, and reinstall A/C vents and power outlet panel.
Once you have the aux input installed in the glove box, you need to run the mini-stereo cable from the glove box to the rear center console. First remove the trim at the side of the rear center console, using a metal spackle knife and pushing towards the rear of the car--instructions here (again compliments of Rudy
under_dash_panel_removal.pdf
![iPod Hardwire Install-6_remove_trim.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8308d1482363340t-ipod-hardwire-install-6_remove_trim.jpg)
Remove screw (red circle) from side trim panel and pull panel toward you and down. After plugging cable into aux input and fishing through back of opened glove box door, run cable into top of panel and behind it
![iPod Hardwire Install-6a_trim_screw.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8309d1482363340t-ipod-hardwire-install-6a_trim_screw.jpg)
Run cable along side of rear center console, and into rear section:
![iPod Hardwire Install-7_wire.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8310d1482363340t-ipod-hardwire-install-7_wire.jpg)
Run mini-stereo cable and coiled wire from Monster iCarCharger into center console compartment below the coin holder--this pic has a white wire for easy identification showing location. You'll need to enlarge the opening, using a Dremel or similar tool, so the iCarCharger plug will fit through:
![iPod Hardwire Install-8_armrest_hole.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8311d1482363340t-ipod-hardwire-install-8_armrest_hole.jpg)
Install coin holder.
Here's the iPod in the armrest:
![iPod Hardwire Install-9_ipod_in_armrest.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8312d1482363340t-ipod-hardwire-install-9_ipod_in_armrest.jpg)
You can remove the iPod from the armrest to change playlists, etc.:
![iPod Hardwire Install-10_ipod_in_hand.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/8313d1482363340t-ipod-hardwire-install-10_ipod_in_hand.jpg)
I ripped my CDs to iTunes as MP3 at 192 kbps, and the sound quality is excellent. Anybody want to buy a CD changer??!!
rear_insert.pdf
fresh_air_grill.pdf
My Ride: '05 545 Sport Week 9
Nice writeup thanks!
What's the coin tray, I don't have that in my car. Was that an accessory? Does it replace the other compartment in the center of the console that is meant for a phone?
Banned
What's the coin tray, I don't have that in my car.? Was that an accessory?? Does it replace the other compartment in the center of the console that is meant for a phone?
[snapback]138136[/snapback]
My Ride: 545i Sport Auto (see sig)
Nice howto. I personally prefer the iPod in front me when I'm driving so I can pause/change music at a moment's notice. Only problem with this is the fonts on the iPod are too small for safe reading at driving speeds, and the wheel too sensitive. I'm going to troll some of the iPod boards and see if there is a way to adjust this.
My Ride: 2005 530i, Jet Black, Black Leather, Automatic, Cold Weather, Sirius Prep and Radio, Premium Package, Xenon Lights.
Doesn't this just seem cooler and way easier?
![iPod Hardwire Install-post_897_1118434890.gif](https://5series.net/forums/attachments/diy-do-yourself-14/8373d1482363340t-ipod-hardwire-install-post_897_1118434890.gif)
TuneBase for iPod mini
Part # F8V7098
The TuneBase for iPod mini mobile digital devices offers the most flexible way to use your iPod mini on the road. The holder features an innovative, flexible-steel neck that easily positions your iPod mini for your comfort, convenience, and safety while driving. TuneBase works through any cigarette lighter outlet within the car.
While mounted in the TuneBase, your iPod mini powers and charges simultaneously. The TuneBase also features a 3.5mm line-out for use with BMW Aux Input for high-quality audio through your car stereo.
The TuneBase makes sure your music goes wherever you do.
Advantages
? Custom-designed swivel-cradle provides a secure and stable connection for your iPod mini
? Features a flexible steel-neck construction that positions easily inside your car
? Features a 3.5mm line-out for use with your BMW Aux Input for high-quality audio through your car stereo.
? Features a dock connector base that locks securely to your iPod
? Comes with a Belkin 3-Year Warranty
Part # F8V7098
Advantages
Banned
Attachment 8373
Part # F8V7098
Advantages
Attachment 8373
Part # F8V7098
Advantages
[snapback]138797[/snapback]
Stream,
I agree that out of sight / out of mind is better. I was holding out for the possibility that the Bluetooth Ipod would be out by summer. That seems unlikely. So before my next summer trip (tour of the Northern Rim of the Grand Canyons), I intend to print and follow your instructions. Great job! Next time your in Colorado Springs, beers on me!
My Ride: X3 | 3.0 | 6-speed manual
As an aside, I never knew that the output from the dock connector provides higher quality sound than the headphone jack. Thanks for that little bit of info, too. It sure makes sense now that I think about it.
After the install, did'nt you need to recode the i-drive to reconize the new hardware? I have a copy of the installation procedure from BMW of N. America and at the end of the steps it says that it needs to be recoded. Tell me if I'm right or wrong.
Banned
[snapback]156466[/snapback]
