IPOD DO IT YOURSELF
Old Mar 12, 2007 | 10:13 AM
euroman2004's Avatar
My Ride: 2004 530i SPORT PKG, HUD,IPOD INTRF, BLUETHOOTH NO MOODS
Hello i just ordered The ipod interface from Garry at newport BMW IT COST $ 225.00 plus shipping its about $65.00 cheaper then my dealer i was going to install it myself then take to my dealer to encoded , but im not sure if its better to take and have them do it all .does anyone here had there ipod installed themselfs if so is it simple to do it? does the the dealr gave you a hard time if you just take in to do encoding?
thanks all for you response
Old Mar 12, 2007 | 10:19 AM
i have one more question i had my bluetooth installed 2 weeks ago. over the weekend it went blank and it does not let me paired anymore its gray screen, when i take it in to dealrs to get it fixed do you think the ipod interface will be upgrded when they work on a bluetooth?
thanks again
Old Mar 12, 2007 | 10:53 AM
Wiu-Bimmer's Avatar
thanks again
No they won't, unless you tell them to. They need to go into the retrofit menu in PROGMAN to enable the iPod interface.
From what you mention regarding BT, sounds like it might be a matter of updating your software or activating BT again and do kind of a reset to your iDrive (Don't know, perhaps your TCU went belly up).
Based on what you mention, I would not mess around with installing the iPod interface yourself, they might claim the BT functionality error caused by your DIY installation. It all depends on your SA/Service dept.
I've heard about members in this forum going different ways regarding the DIY install for the iPod interface. Some have not removed the glovebox and that is the easiest way. Some other remove the glovebox and that might take some more skill and more time.
On my personal experience, I removed the glovebox and followed all the installation instructions and comments from forum members, it took me a good three hours plus to do the complete install (Took me a while, I know). By the way, might be common sense but those pads with adhesive that the iPod interface comes with, both are for the top side of the unit, to kind of glue it to the top metal part of the CD changer housing, then you use the straps to keep it there. I did not see that little piece of info anywhere here and it took me a while to figure it out (Duh!).
Good luck
Old Mar 13, 2007 | 08:48 AM
Good luck
thanks for your reply, im going to install it myself then take in to have them check the bluetooth and encoded ipod, from what read here ipod and bluetooth are completely different programming is that right? thanks
Old Mar 15, 2007 | 01:20 AM
pro2cer's Avatar
My Ride: "Angel I's" 2005 525i Debadged, Remote Homelink, Full Burl Package, Cold Weather PKG, Premium Sound PKG, BMW Wheel Stems, Biege Rubba Matz, EURO Tag, Dual Zone Vents, Automatic Car Ventilation, Rescue Kit. Due up: Aux Input, TINT, and K&N Filter and some Zaino LOVE for my Angel.
Post
Before you take it to them, see if it works without encoding. There's someone who did it without encoding. Here's the deal, IMO..If you have the CD Prep or if you've had the Changer, you're just using the controls from the CD Changer in the Menu. CD1-CD6 is there waiting to be used. It may also depend on your CIP or Progman version. I talked to Gary about it also, and that's a good price. If all else fails, the programming shouldn't be 3 hours as stated unless again, unless you have an OLD progman version. I was quoted a price of 375 for EVERYTHING...TOTAL because of the doc showing the install time to be .075 HRS.
It probably doesn't include programming, but my SA didn't care....He's KOOL man. Good Luck.
Let us know what happens!!!
Old Mar 15, 2007 | 03:15 PM
pa550's Avatar
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
What year car, CIP level and do you already have a CD changer? Depending on those, you may need a re-coding.
The iPod install itself is very easy. Search the site for the DIY instructions. I even posted the correct part number for the cover that fits over where the CD changer used to sit.
Old Mar 15, 2007 | 11:45 PM
thanks ... My e60 built is 07/04 it does not have cd changer but it does have changer ready as far CIP level im not sure what i have .i do know they did some kind of upgrade 2 weeks ago when they activated bluetooth i noticed some changes on idrive like map radio etc . How can i check what level CIP i have ? thanks again i will post after ipod installed.
Old Mar 16, 2007 | 07:38 AM
Wildcat's Avatar
My Ride: 2005 545i, Orient Blue/Beige, Navigation, Premium Sound, Cold Weather, PDC, split-folding rear seats, DIY iPod. DIY Valentine 1 hardwire, loose nut behind the wheel.
Did you happen to get a copy of the "Measures Plan" or "Final Report" from the dealer? Those will have a code on them called the "Target Data Status", which can be translated to your PROGMAN version. If it's E060-06-12-510, then you have version 24.xx
However, I believe from what I have read on this forum, the only way that the iPod adapter will be recognized without a software update is if the CD-changer was already installed. Even if you have the most recent PROGMAN, your car's CPU hasn't been told to look for the changer/iPod adapter. That little piece of coding will have to be done by the dealer, but BMW NA's stated install time is .75 hours. Don't pay more than 1 hour's labor for the encoding, especially if you do the hardware install yourself.
bestofthebest
Mar 28, 2016 02:47 PM
bestofthebest
Jan 5, 2016 07:47 PM
umichchris
Dec 7, 2015 03:33 PM
Bank$hot530
Sep 16, 2015 01:28 PM
kcrokin
Aug 20, 2015 03:54 PM
