i keep bending my rims!
My Ride: 2013 535i xDrive AW/Black M-kit
so i have a 07 530 with OEM m5 rims on there. ive bent and repaired my rims about 8 times this winter and i dont even remember hitting anything! wtf is going on? anyone else having this problem? i have kuhmo ecsta spt's
front 245/35/19
rear 275/30/19
can i get 40s on both or will there be fitment issues? ahhh i dunno wut to do!
front 245/35/19
rear 275/30/19
front 245/35/19
rear 275/30/19
front 245/35/19
rear 275/30/19
Any tire damage as a result or only rims getting beat?
My Ride: See my signature
If you are using your E60 as a daily driver in a NYC winter, you should get 17s or 18s for your winter wheels. You need more sideall.
Banned
My Ride: A Car
245mm = 24.5cm/2.54cm/1in=9.64inches on a factory M5 wheel which rear is 9.5 inches. If someone confirms M5 rear wheels are 9.5 inches, you can use it. If m5 rear is 10 inches, u are risking it. Might as well get 255 all around if that's the case. Hope this helps.
