how to reset air mass values inpa
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi guys does any one know how to reset the air mass sensor values on inpa? fitted a used air mass to a friends car which either needs registering or values reseted thanks
First, clear the error memory. Shadow, history error.
Then you need to reset adaption.
Select E60. Go into the the engine. I believe "activate" then "adaption"
Clear all adaption values.
Car must be OFF while doing the above.
i dont think i get any options for adaption reset in inpa under engine just to register injector nothing more
which version of inpa are you using to do this thanks
and which car do you have i have a 530d 2003 petrol may be different
BallyM5, you will just need to clear the error memory and reset the adaption values.
It does depend on the MS version you are using. I believe AchtungE60 is using MS43 or MS45 from the way he is describing it.
For you, you will need to use either DDE 5.0 or DDE 6.0 and the options may be different.
