How to replace the Spark Plug # 4 on 545i
Did this today. Wasn't as bad as I thought. Took me 3 hours all and all, start to finish, and I've never done this before. I was mentally preparing for at least a 5 hour ordeal. Coils came out with no problems. I had a little trouble with the #8 (driver side) plug, but I did driver's side first, but then once I figured out the combination of extensions and flex joint that worked it was all a breeze. The 5/8" spark plug socket --> Flex joint (3/8") --> 3" extension (3/8") --> Flex joint (3/8"). Plug that into whatever wrech you're using and you're good to go. Of course you still gotta move some shit out of the way, as mentioned in the diy.
After many users ask how to replace the spark plugs on 545i as DIY. I decided to make this.
Sorry, I made it fast and hope you get it. (a picture = 100000 words)
Let me know if you have more questions....
To see the PDF: Attachment 59681
I have replaced 1-3, may skip #4, install 5-7 and save 4&8 till I gt the correct extension or tool
My Ride: 05 545/6
My Ride: 545i
Im a newbie to the sight but I was looking to change my plugs after I started to feel it misfire. Couldn't have done cylinders 4 and 8 without your right up. Thanks a million!!
socale39
09-05-2023 08:30 AM
chadillac2000
42
09-13-2017 11:15 AM
