How to lock crank from Spining need to replace 530d auto?
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys I need urgent help with removing my crank pulley as I started getting a burning smell on new years day when I was in London when I opened the bonnet I noticed the belt wasnt Spining as fast as it should got it home slowly without using too much engine power and without putting strain on the power steering as this kept on going hard every now and then
Got it home checked the crank pulley plastic has cheesed off the metal mounting its the genuine bmw one looks like the same one since the car was built
I pulled off the melted part of the pulley off now I'm left with the metal part which is mounted by four bolts
When I try to undo this the crank spins as in the engine is turning how can I lock this from Spining so I can undo the nuts and replace the pulley
Thanks
I did notice the pulley Spining a little unevenly few weeks ago but was very minor
The metal part spins evenly
Thanks
DavaiLave
08-02-2022 02:16 AM
Stormcrow
12-01-2019 02:09 AM
TexaZ3
05-06-2015 09:54 AM
