How do you separate the bulb from the balast?
OMG... I removed the headlight and took out the bulb with the balast...
But... I was not albe to separate them... I am so... pissed...
Please helppppp... I searched... but no one explained about this part...
Thanks guys...
Thanks guys...
My Ride: G30 M550i
Model Year: 2018
I'm not sure if this is something that can be separated. From the looks of the parts diagram, it seems as if they might be using a newer style bulb that has the "ignition element" fixed to the bulb...
http://www.realoem.com/bmw/showparts.do?mo...hg=63&fg=05
Originally Posted by jhhwang82' post='433579' date='Jun 9 2007, 12:14 AM
I tried to seprate the bulb from the balast and it was not possible...
I think the part is assembled together... 07 model sucks...
Thanks for your help Rudy...
Check and point it's position before, so you won't have troubles with it's orientation when re-installing it.
I tried to remove it..... I was at the point where the bulb might crack...
I did not even move a bit... I mean I won't take a chance...
Originally Posted by nicke60gre' post='433582' date='Jun 8 2007, 02:28 PM
Remove the hi-voltage wire, unclip the holding clip and turn the ballast counterclockwise.
Check and point it's position before, so you won't have troubles with it's orientation when re-installing it.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
My Ride: G30 M550i
Model Year: 2018
Nick, are you sure all of the bulbs are removable? If you look at the page I linked to in post #2, it looks as if there might be two versions of the bulb, one removable and one not...
jluzbet
11-07-2015 01:25 PM
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
