How to change AC belt?
My Ride: M6 E63 Sapphire black
Z3 Coupe R4Turbo Hellrot, semi race. (670bhp)
Z3 Coupe V8Turbo design work ongoing, full race.
Sold: 545i Titanium Silver
My car have started to squeal and humming a little, probably from the belt drive, when started and rolling off in cold conditions.
My plan is to change the AC belt and generator/waterpump belt, together with the adjusting pully and deflection pully.
So far so good.
Then I had a look at the engine and discovered that the AC belt does not have an adjusting pully!
![How to change AC belt?-p3230038.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/46838d1482366113t-how-change-ac-belt-p3230038.jpg)
![How to change AC belt?-p3230039.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/46839d1482366113t-how-change-ac-belt-p3230039.jpg)
How to remove tension on the belt to be able to change it?
(E65 have an adjusting pully on this belt
So far so good.
I have got the suggestion, from another forum, to release the ac compressor and tilt it.
What do you think? Would it be possible to do it in any other way?
My Ride: G30 M550i
Model Year: 2018
MST_Replacing_A_C_compressor_drive_belt__N62____no_tensioner.pdf
Rudy>>
As said in Swedish, tusen tack!
Many thanks
Many thanks
socale39
09-05-2023 08:30 AM
