How can I adjust the head light beam
My Ride: Stock for now
I just bought an 04 545 and I noticed the head light beams are not even and wanted to know if its a simple adjustment that I can make to align the beams. I have done a search but have not been able to find how to do the adjustment. Can someone point me in the right direction? I see there are two allen head screws on the top of the light. Are these the ones to adjust the lights or to remove the unit.
Banned
My Ride: A Car
those are to adjust. the one closer to the fender is for left and right. one closer to the kidney grills are for up and down.
My Ride: G30 M550i
Model Year: 2018
Before you adjust things on your own, be aware that they're not supposed to be "even" and adjusting them to a point that makes you happy might end up blinding or otherwise annoying oncoming traffic.
If you still feel something needs adjusted, the best place to get it done is at a dealer who can utilize the proper equipment to make sure things are done to factory specifications. When things are aligned properly, the lights do a great job.
If you still feel like tackling things yourself after reading the above warnings, then take a look at the following:
http://forums.e60.net/index.php?showtopic=21988
http://forums.e60.net/index.php?showtopic=31633
http://forums.e60.net/index.php?showtopic=66421
