9 Attachment(s)
Here are some pictures of my installation of my garage door opener.
I was looking for a tactile switch to mount in my roof of my E60 to operate the garage door. The only switch avalaible was a "SOS" button according to the dealer (27 euro's). I bought this switch and mounted next to my electronic-roof switch. Attachment 16244 If you press this switch, a mini door opens, and another button is behind it Attachment 16245 When you open the overhead compartment, the best is to use a big screwdriver (or a knife) Attachment 16246 Attachment 16247 Attachment 16248 Attachment 16249 You see my normal chaimberlain garage door opener, I opended it, removed the button-plastic, and connected 4 wires, 2 from the switch, and 2 from the LED. The "SOS" switch what I bougth needed sosme modifications, because there is a mini-PCB inside this switch, and cut som printed wires, you have to know something from electronics if you midify this, because the "SOS" switch led's have a anode (+) and kathode(-) so I connected the led of the original door opener, to the led of the "SOS" switch, the same with the switchcontacts. as you can see on the picture Attachment 16250 What you see on this picture is dualsides sticky tape to fixate this to the panel Attachment 16251 The end result: Now when I press the button, the garage door opens an the led lights up...... Attachment 16252 |
That's an interesting idea. I'm not sure what country you're in but I guess you don't have the SOS switch already installed for the BMW Assist service. Would the rear-view mirror with the homelink transmitter have worked? (I realize you're method is probably less expensive to do.)
Quick question, what do I see to the right of the sunroof switch? |
Quick question, what do I see to the right of the sunroof switch? I'm living in the netherlands, and I installed the SOS switch, not BMW. Of course the homelink would have worked, but it was not my intention to buy a new mirror for 300+ USD What you see next to the sunroof switch is explained here: http://forums.e60.net/index.php?act=ST&f=1...t=0#entry250042 |
Nice install , Great job
Now I see what that thing it. Pretty cool! Nice work!!
good job man...looks really good....i may consider this....but i think it would be too dificult to install the button in the over head compartment...im afraid i will do it wrong and miss up the car....but the wiring should be easier...how did you install the button...was it already there...or u made a whole..
1 Attachment(s)
See next
There was no hole , I did it myself Mayby this explains more: Attachment 16277 What you can do is to drill a line of holes (horizontal) in the middle, so the plastic pops out more easely |
thanksssss alot for the reply... you have been very help full...ill have to buy a new grage remote.cause there are two remotes and three cars...soo first ill go look for a remote...i must admit im still abit afraid about the overhead compartment....i will never forgive my self if i screw it up....ehehheh....maybe ill check if the dealer will pop the buton in place.and then i finish of the wiring....but its a greatt idea...thanks...
Good work :thumbsup: Saved quite a few $$ (or Euros) with this method and looks OEM to me. And good DIY instructions. More :thumbsup:
