front ashtray
My Ride: 525ise, Dec 2003, Silver Grey, Black Dakota Leather, Bluetooth, 18'' Runflats, Folding mirrors, Automatic/man box,parking sensers front/rear,latest addition 645ci black saphire, with everthing on, nothing it does not have.
i have a dock extender cable which i will run from ipod connection from glove box (not a problem) i am going to mount the dock part of the ipod in the ashtray container like someone else has done on here, but how do i get the cable to this point, any help would be great.
My Ride: Estoril Blue 440i GC
Model Year: 2017
I've not done this but . . .
Try routing the cable forward and towards the centre console.
The carpet strip that is under the centre console, but above the string vest pocket just slides out. This will reveal a screw.
Undo the screw and it then may be possible to route the cable behind the centre console plastic, on the transmission tunnel, then poke the plug up to the ashtray holder. You can get the ashtray holder out without removing the console trim, but you need a small screwdriver bit and a small spanner to turn it, as well as a bit of patience, to get the front screws out of the ashtray.
Otherwise, remove the dash trim (which involves the horizontal trim across the dash coming off to reveal mounting screws for the vertical section). this will give you a route to furkle a wire from the glove box, under the CD player and to the ashtray.
Mike
Mike
sorry should have said this will be going in my 645 not 525 does all above still apply
Model Year: 2017
Have you got one on Sport??
Sorry, I'm not familiar with the 6 series, but having a glance at the TIS, you haven't got the carpet trim panel to slide out on the 6. Perhaps if you took off the panel under the glove box, then you could see about getting the cable between the carpet and the centre console.
Mike
Mike
any help would be good
TexaZ3
05-06-2015 09:54 AM
