Fixing front cigarette lighter ?
Anyone have any tips on getting my front cigarette lighter back into place?
I was detailing the interior and pushed the lighter a little too much and it fell inside its normal position.
I cant figure out how to get it back into place so it will pop up when I open the cover.
My Ride: Estoril Blue 440i GC
Model Year: 2017
Raleigh,
Lift the gear lever gaiter up - it's only plastic clipped in - fingernails usually do the job OK. Otherwise, remove the gear knob with a sharp pull upwards (don't twist), but watch your head as when the knob comes off, it will come off quickly and may hit you!!
You will now see 2 x Torx screws. Undo them.
Pull off the iDrive knob (straight up).
Now the good bit. Get your favourite large screwdriver and lever off the trim panel. The panel is only pushed in, but may be tight, so be careful levering the securing pins. The trim panel, along with the ashtray lid will then slide out after removing the switch plug.
You will see the ashtray/lighter assembly held by 4 screws, 2 are easy to get at, 2 need a short driver bit with a spanner to turn it ( the gap between the screw and the underneath of the centre upright panel is about 1" (2.5cm)).
Unplug the lighter and take the assembly to your bench (or kitchen table, whichever you prefer!) You should then be able to see if there is anything broken or it is just sticking down.
This job will take about 30-40 minutes to do the first time, but when you've done it once, you will be able to get the centre trim out within 5 minutes!!
Good luck
Mike
Good luck
Mike
Originally Posted by AlwynMike' post='481392' date='Oct 14 2007, 12:18 PM
Raleigh,
Good luck
Mike
Good luck
Mike
Originally Posted by Russ1974' post='481367' date='Oct 14 2007, 10:07 AM
It has various springs/clips - hard to describe but if you can't pull it out, it's possible you've broken it. I removed this from my car along with the ash tray as I fitted an iPod interface/holder - it was a pain to take the cigaratte lighter out and I had to snap / break it to remove it - the first stage of the break was pushing it inwards so it fell flat, which sounds like the stage you've got yours to. When I then forced it back upwards, various bits went "snap/crack".
When it comes to cigarette lighters, breaking them is the best way to go. Im anti smoking and think the idea of smoking inside a BMW is total insanity. Of course if you are addicted to nicotine thats a different story.
Model Year: 2017
Smoke in the car and destroy that nice leather smell. No way. Some of us need the socket for phone chargers, laptop power supplies etc.
(No I don't smoke - in or out of the car. I have enough filthy habits without that one!)
Mike
Mike
My Ride: 9/2003 E60 520i SE
do you have any pics of your ipod interface/holder? i was thinking of doing the same. would be interested to see how it turned out.
thanks
My Ride: 2006 530xiT, Sep. 2005 build, silver gray/gray/black anthracite, Steptronic, Premium, Premium Sound, NAV, PDC.
My Ride: E60 530d 218ps
just to add that i'm in the middle of replacing /repairing the front ashtray, and its such a b!tch of a job!!!
the trim needs superhuman powered fingers to pry
now i'm faced with finding short screw bit to undo the ashtray.....
why oh why did i break the bloody lighter in the first place...
Awest91
09-17-2022 11:05 PM
