Fixed the gap between hood and M-Kit Bumper
Old 03-16-2009, 05:27 PM
  #21
Bartman's Avatar
Brilliant job m8 and a good idea, think mine could do with this sorting out, it's a 2005. A gap like this should'nt exist on a car of this build quality from the factory.
Old 09-04-2010, 02:38 PM
  #22
TAmes's Avatar
I realize I'm resurrecting a very old post here, but I did want to share my experience and thank rodybmw for his very thoughtful post. I am not at all mechanically inclined, but I was able to reduce the bumper gap in my 2010 550i to 3.5 mm, from about 5 mm. This doesn't sound like much -- and it isn't -- but it was always frustrating to me that the gap was so wide: it just seemed sloppy.
My M-tech bumper is OEM, so I didn't think that the foam method would really apply. Instead, I simply used 5 2 mm steel washers and slid them under the panel that rodybmw illustrated. I couldn't find wider washers, but I think I may be able to close the gap even more by slide a polyurethane washer under the steel washer to lift the bumper just a little bit more.
Old 09-06-2010, 02:12 PM
  #23
inktoxicated's Avatar
My Ride: 2006 530i mystic blue
since your a pro now at taking off that front bumper what other bolts need to be removed other then the 5 torx on the tops?
Old 09-06-2010, 04:44 PM
  #24
TAmes's Avatar
I didn't take the front bumper off completely...I just slid the washers under the 5 torx on the top without taking off the entire bumper.
Old 09-12-2010, 04:52 AM
  #25
yea i mean what bolt other then the 5 on top need to be removed to take bumper off,, are there some near the fog lights or fenderS?
Old 10-01-2010, 09:42 AM
  #26
healthservices's Avatar
http://forums.5serie..._1#entry1238380
Old 07-31-2012, 12:38 PM
  #27
Gixman's Avatar
Does anyone know if the foam insert part numbers listed above will work on my 2008 535xi? I installed the Mtech bumper and I'm do have a bumper/hood gap issue.
Old 05-06-2014, 10:55 PM
  #28
resunoiz's Avatar
My Ride: 520i E60
thanks for the guide (I made a search some days ago and found nothig). I have the same issue with normal bumper.
socale39
09-05-2023 08:30 AM
Kasmo
05-07-2019 03:30 AM
NickP
07-15-2004 11:18 AM
alohalc
07-07-2004 05:54 PM
rem
12-09-2003 06:53 AM
Quick Reply: Fixed the gap between hood and M-Kit Bumper
