Fitting non runflats to e60
Hi, Fitted two new rear tyres yesterday to my E60 530d normally running on runflats, now i-drive is telling me that i have a punture? which i dont have, can anybody tell me please how to get over this warning, and cancell the message on the computer, many thanks Dave
My Ride: 2005 BMW 545i Sport Package, Jet Black
M166 OEM Wheels
M5 Style Body kit
RPI Scoop
BMC Air Filter
Valentine One Radar Detector
35% tint all around
when i changed my tires it said "FLAT TIRE". I put correct pressure to all tires and did a RESET. pretty easy. Is that what u asking? I don't know what punture is
Originally Posted by NeRwEEzy' post='828311' date='Mar 27 2009, 05:35 PM
it is necessary to reset the flat tire monitor when getting new tires
My Ride: 530D M Sport E60, media pack, bluetooth, pro nav system
I know this because I got 2 miles down the road from buying my car and this happined to me, turns out the stealer hadn't reset the system after servicing the car before I bought it
Btw I'm not far from you, Sheffield, small world eh
Mick
ps, your supposed to do this every time you adjust the tyre pressures, page 87 in the manual
Puncture, English for flat tire
Originally Posted by wickster' post='828325' date='Mar 27 2009, 05:55 PM
Ok Dave, with the ignition on but car not started, your idrive will show on the screen, when your idrive is in the normal setting, ie waiting for you to choose nav, entertainment, communication and climate, press the controller down. This will bring up the i menu, go to vehical settings and press the controller. Select RPA and press the controller. Start the engine, now select set tyre pressure and press controller, select yes and press controller, now drive off, the message initialising is displayed, which it does as you drive, it will then say status RPA active again.
Mick
Mick
Originally Posted by m3evo' post='828331' date='Mar 27 2009, 06:00 PM
Cheers Mick, Will try that tonight, forgot to say that i replaced the runflats with normal tyres! will this make any difference thanks Dave
bestofthebest
Mar 30, 2015 08:12 PM
