Engine coolant - Put in the wrong stuff help...
My Ride: 2006 525Xi
2001 Volvo V70 T5
1957 Higgins Sports Speed Speedster Deluxe - All Mahogany
Hello,
Thanks in advance. The engine coolant level warning came on today. I checked the level in the engine and it was quite low. I foolishly put in a non BMW coolant (the green stuff) and then realized what I had done. What should I do? Is it ok? Should I flush the system (any diy information). I haven't started the car yet.
Thanks again,
Edwin
Thanks again,
Edwin
My suggestion is to maybe drain the reservoir. You said you have not started the car as yet, so any coolant added will still be in the reservoir. I do not know if the green stuff is compatable. Hope this helps.
My Ride: 2006 525Xi
2001 Volvo V70 T5
Thanks for the reply. How do I drain the reservoir? Is there a plug somewhere?
Thanks again,
Edwin
Thanks again,
Edwin
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
Thanks again,
Edwin
Thanks again,
Edwin
My Ride: 2006 525Xi
2001 Volvo V70 T5
I used an aquarium siphon and sucked out at least a litre. I then filled with water and did it all over again until the fluid was clear. I will top off with the proper BMW coolant.
Thanks,
Edwin
Thanks,
Edwin
