Enable TV Function/Video modul with NCSExpert
My Ride: BMW E61 525D 2008 m-sport
Hi
I've installed a Dension GW 500 with the AVR modul. I'm now trying to enable the TV Function on my CCC. It's E61 2008 without OEM TV Tuner. I've installed NCSExpert and I'm able to read the data from the the CCC modul. Does anyone know how to enable the TV Function on the CCC?. I've found these value in the FSW_PSW.TRC file:
TV_FRONT_ENABLED
nicht_aktiv
VEHICLE_FINDER
nicht_aktiv
VIDEO_DENY_C0B
deny_slow_key
ONLINE_DAR_TYPE_B
dar_ece_gprs
VIDEOMODUL_CCC_B
nicht_aktiv
TV_FRONT_ENABLED
nicht_aktiv
VEHICLE_FINDER
nicht_aktiv
VIDEO_DENY_C0B
deny_slow_key
ONLINE_DAR_TYPE_B
dar_ece_gprs
VIDEOMODUL_CCC_B
nicht_aktiv
Why not just add the VO for TV and the recode the CCC.
That could be a good ide. Not sure ho to add the TV for the VO with NCSExpert. Can i change the VO without recoding the whole car? Or do i just change the VO in NCSExpert and recode only the CCC with this new code?
You need to add the FA number to the VO which is held in the CAS and LMA then re-code the whole car, it must be done this way so that all the relevant functions are set in the required modules.
Some functions are split across modules.
