Easy standard stereo sound upgrade
Old 03-22-2010, 01:48 PM
  #31
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
Originally Posted by StreetPro
I have added tweeters with ZERO issues, no damage to HU after a year or so... the difference is HUGE, without them it was like a fight in mud and fog :-)
Did u add tweeters to the front and back (4 in total)?
Old 03-24-2010, 02:08 PM
  #32
dieseltouring's Avatar
Hi,
I have now added the L7 tweeters in the front and rear, installed SWS-8 subs under the seats and a pair of blaupunkt pnp amps. The result now sounds really superb. However, the biggest gain came from just fitting the front L7 tweeters driven from the standard head unit. This alone gave 80% of the improvement.
Old 03-25-2010, 11:27 AM
  #33
jas_r_1's Avatar
Are you able to add the rear tweeters, as well as the front tweeters, and power them
through the head unit?
Old 03-25-2010, 01:45 PM
  #34
Yes, I did just that before buying and adding the amps. The rear speakers have a socket to accept the tweeter just like the front ones do. It's all plug and play. The tweeters add very little extra loading for the head unit.
However, some say tweeters at the back are a bad idea. That they corrupt the stereo image and pull the soundstage back and it is better to have all the high frequencies up front "on the dash". Personally, I prefer the sound all around you.
Old 03-25-2010, 11:11 PM
  #35
jas_r_1's Avatar
Thanks for replying. Sounds like a cheap mod with good results.
Time to buy some tweeters!
Old 03-26-2010, 03:45 PM
  #36
Don't think you will regret it. well you might half way through removing the door cards. It's a bit scary pulling your pride and joy apart but the result is worth it. Best of luck.
Old 03-27-2010, 12:39 AM
  #37
jas_r_1's Avatar
That's what I am worried about - hopefully the DIYs here will be spot on.
Old 03-29-2010, 10:02 AM
  #38
rik_dutch's Avatar
My Ride: BMW e61 2006 520d, chiptuned to 180 hp. 18" 124's
Dieseltouring,
I am also adding the tweeters in front, and I will install the L7 doorspeakers instead of standard. Just bought a pair on Ebay
What I have not really decided , is whether or not to install a Pnp blaupunkt amp.
Just out of curiousity: Which type did you install, and how easy is install?
Secondly, how is your setup, how much channels are you using?
Where did you buy it, since it is out of production?
Thanks,
Rik
Old 03-29-2010, 01:21 PM
  #39
BLooD's Avatar
Hey Jas, it makes a big difference to the sound, i also added the L7 speakers as well they are much better than the stock speakers.
Old 03-30-2010, 01:56 PM
  #40
Sanj's Avatar
Hiya guy's where's the best place to buy these tweeter's?
Quick Reply: Easy standard stereo sound upgrade
