E61 - How to Change Battery
My Ride: 525dat
Heres some pics of where the battery is and how easy it is to change it.
Please note that I have read on another forum that it is necessary to reset the brain so that it knows the battery has been changed. This is apparantly due to the charging profile.
The Battery is behind/under this cover
![E61 - How to Change Battery-21.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137473d1482365168t-e61-how-change-battery-21.jpg)
Remove the 3 screws and lift off the cover
![E61 - How to Change Battery-22.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137474d1482365168t-e61-how-change-battery-22.jpg)
The saftey bar can then be removed by unscrewing the 2 screws at either side
![E61 - How to Change Battery-24.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137476d1482365168t-e61-how-change-battery-24.jpg)
Unscrew the clamp holding the battery in place
Disconnect the Negative first and keep it away from any bodywork! A tip is to put a cloth around it!
Then disconnect the Positive
Change the battery and repeat the procedure backwards..... Positive first!
These are powerful batteries so be careful..!!
This work should only be carried out by qualified personnel
![E61 - How to Change Battery-20.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137472d1482365168t-e61-how-change-battery-20.jpg)
![E61 - How to Change Battery-23.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137475d1482365168t-e61-how-change-battery-23.jpg)
![E61 - How to Change Battery-25.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137477d1482365168t-e61-how-change-battery-25.jpg)
![E61 - How to Change Battery-26.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137478d1482365168t-e61-how-change-battery-26.jpg)
![E61 - How to Change Battery-27.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/137479d1482365168t-e61-how-change-battery-27.jpg)
My Ride: 2004 E61 530D - Dynamic Drive - Active Front Steering Sport Seats - Voice Control - Head Up Display - Nav Pro - Bluetooth - Panoramic roof - Front/rear heated seats
Nice DIY,
Even when not replacing but just disconnecting it is great for those who never did it. And we all know that for almost all the work on these cars you have to disconnect the battery...
Hi !
I add to this tutorial that a "battery registration" action must be taken through GT1, other wise you might get false errors on OBC and IBS might not correctly manage battery charge.
Matt
Matt
My Ride: 525dat
Thanks Matt!
GT1 (Group Tester One):
http://www.auto-diagnostics.info/bmw_gt1
OBC (On Board Computer)
IBS (Intelligent Battery Sensor)
socale39
09-05-2023 08:30 AM
