E60 Brake Pad/Rotor Replacment
My Ride: E60 530i
Engine: M54
Hi,
Is there any DIY instruction for the replacment of the front brake and rotor including the torque specification in the E60 ?
Thanks,
Ching-Ho Cheng
Thanks,
Ching-Ho Cheng
My Ride: G30 M550i
Model Year: 2018
Ching-Ho Cheng,
It took a bit longer than I thought but here you go...
(in my opinion, this isn't worth the DIY if you're still under warranty in the US)
Instructions for replacing front brake linings (pads):
MST_Replacing_brake_linings_on_both_front_disk_brakes.pdf
Instructions for replacing front brake disks (rotors):
MST_Removing_and_installing_both_front_brake_disks.pdf
(As always, you can follow the embedded links in the document (marked by a rectangle around the text) and you can navigate the document by using the bookmarks or Adobe's "back" button.)
My Ride: E60 530i
Engine: M54
Originally Posted by Rudy' date='Mar 17 2005, 01:28 AM
Ching-Ho Cheng,
Attachment 5815
Attachment 5816
Attachment 5815
Attachment 5816
[snapback]102679[/snapback]
Thanks for the instructions. US dealers (Boston) refused to cover the cost to replace the brake rotors even my car is still new and under warranty. They said that rotor wrappage due to corrosion is not covered under the brake/rotors warranty !!!!
They are going to charge me a leg or an arm to replace the rotors. I would do it myself.
Thanks again.
Ching-Ho Cheng
My Ride: E60 530i
Engine: M54
Originally Posted by Rudy' date='Mar 17 2005, 10:11 AM
Good luck then.? Let me know how everything worked out and let me know if I forgot anything in the instructions...
[snapback]102827[/snapback]
I looked at the instruction, it showed me everything that I need to know especially the torque spec.
Thanks,
Ching-Ho Cheng
My Ride: 2008 550, Carbon Black Metallic, Natural Brown Dakota Leather, Sport Package, Sport Automatic Transmission, Cold Weather Package, Power Rear and Manual Side Sun Shades, etc.
Retired - 2004 545 SMG, Black Sapphire Metallic, Auburn Dakota Leather, Cold Weather and Sports Packages, Power Rear and Manual Side Sun Shades
Originally Posted by lcc014' date='Mar 17 2005, 08:12 AM
Thanks for the instructions.? US dealers (Boston) refused to cover the cost to replace the brake rotors even my car is still new and under warranty.? They said that rotor wrappage due to corrosion is not covered under the brake/rotors warranty !!!!
They are going to charge me a leg or an arm to replace the rotors.? I would do it myself.
Thanks again.
Ching-Ho Cheng
Thanks again.
Ching-Ho Cheng
[snapback]102780[/snapback]
I would not let them off the hook so easily. unless you did something to intentionally abuse the car, the rotors on a 2005 should not have corroded so much so as to warp. Talkl to the sales manager, and if that does not work, talk to BMWNA.
My Ride: 2008 535i, 6spd mtx, Monaco Blue w/Beige interior. Sport, Preimum, Logic 7/HD/I-Pod/USB, Nav sys, rear sunshade, HUD, PDC, Split seats,
Good advice...brake rotors should not be overly sensitive to corrosion - especially since they are a "safety" item on the car...if you are under warranty, BMW should cover this....
Originally Posted by Rudy' post='509580' date='Dec 22 2007, 08:04 AM
I would think after more than two years, this issue has been resolved... ![Confused](https://5series.net/forums/images/smilies/confused.gif)
Rudy...should be right...not sure how this thread popped up to the forfront again and I didn't notice the date...but now that you mention it they are old posts. I must be losing my mind as I promise I didn't go back several pages a dig this up
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
My Ride: G30 M550i
Model Year: 2018
Originally Posted by HotLap' post='509582' date='Dec 22 2007, 11:07 AM
Rudy...should be right...not sure how this thread popped up to the forfront again and I didn't notice the date...but now that you mention it they are old posts. I must be losing my mind as I promise I didn't go back several pages a dig this up ![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
