E60 550i Aux cooling fan motor replacement
Old 07-25-2018, 01:42 PM
Jason Osborn's Avatar
My Ride: 530i touring se
Model Year: 2002
Default Advice
Originally Posted by Jeff Bergman
I hope this thread is still good. I have an 08 550i. I was told by BMW that my fan needed to be replaced. I replaced it with a genuine BMW part. It was not a fun job. It's all hooked up and still no fan action. I also replaced the thermostat with sensor, and the lower radiator hose sensor.
Any suggestions? Fuse? Does the car need to be programmed to recognize the new fan?
Did you ever ever get to the bottom of this as I have the same problem with my e39 ? Cheers Jay
Old 06-02-2021, 01:48 PM
Uwe
Uwe's Avatar
My Ride: 2008 BMW 550i
Default Auxiliary fan not working
Did you ever get that fan to work? I have the very same issue with my 550i
Old 06-02-2021, 03:09 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
There are too many things that can cause your issue. It's best to scan the car via BMW code reader so you don't waste money replacing parts you don't need.
Old 06-02-2021, 03:26 PM
Uwe
Uwe's Avatar
There
I have no codes regarding that issue coming up
Old 06-02-2021, 04:42 PM
Model Year: 05 530i
Engine: 3.0 M54
Originally Posted by Uwe
There
What did you use to read the codes? If the fan is not turning on then there is a code.
Old 06-02-2021, 06:04 PM
donpb's Avatar
My Ride: '06 530i N52
There
Which code reader are you using?
hks
10-20-2015 01:30 PM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
buzz729
01-20-2015 07:25 PM
buzz729
01-17-2015 08:54 AM
kimfoghlarsen
02-12-2011 12:38 PM
Quick Reply: E60 550i Aux cooling fan motor replacement
